1 - 4 of 4 Posts
I bought a promaster about a month ago from a private seller who'd put 11,000 on it. It had a partition and some shelving which I removed. My plan is to do a conversion and travel the country. I've been doing home remodeling full time for years but this is my fist van conversion.
First thing I did was insta the fantastic fan. There's something special about cutting a 14" hole in the roof before you've made a payment on the van. Thankfully everything went off without a hitch and there have been no leaks. Next I installed the 14"×21" windows on either side of the van near the rear. I cut the holes with a 3/8 drill bit and a jigsaw fitted with a fine tooth metal blade. I filed the burs, primed the raw metal and used butyl tape on both the windows and fan. I also used a lap sealant on the roof to cover the screw heads.
I bought 125' sq. Ft. Of Fatmat rattletrap sound deadner, I'm impressed with how much a difference it made! After the rattletrap was in installed 1/2 polyiso rigid foam board with a reflective face was glued to the walls. 1" board will be glued to the ceiling. After that it's on to the floor!
The RD seal of approval for what you have done! Please give us more pictures! I got rid of the stupid seals gif.
1 - 4 of 4 Posts
