This week I almost finished the process of installing panels covered with fabric. It can be tedious, but I feel good about how it's come together. I have progressed in my expertise with spraying contact cement.
Thank you! I'm excited to move on to building the final two areas: kitchen/galley and bed/garage storage area. Then we can begin using the camper!Looks Great @Dennis CampMaker 😁👍
That would have been an option. I was mainly following the existing patterns on the door. The amount of exposed metal isn't huge, in terms of insulation loss.Dennis, I’m wondering why you didn’t put a single large piece of plywood (or 2) over the entire slider, but left several metal surfaces exposed?
Inquiring mind wants to know…
Waht did you cover the open areas with?This afternoon I finished the area above the slider door. I'm becoming a fan of the 4 way stretch "trunk" fabric. It only took about 45 minutes. I'm fairly pleased with how it turned out. It isn't glued in place. It's just held in place by the adjacent panels, the two D ring anchors and the extra fold from the weather stripping.
I had some fabric from a few years ago, but this is a link to similar material. HOMCHEK 40" × 78" Grey Speaker Box Carpet Resists Stains Non-Woven Fabric Cover | eBayWaht did you cover the open areas with?
I decided to cover the facia board with fabric to match the ceiling.I think this is one of the best ways to finish off the area above the back doors. This is accessible since I have many wires inside. View attachment 86429
Coincidentally, I was just at the shop today who fabricates those tanks for Curious Campers as I was ordering a fresh water tank for my cabin (240 Litre).The next phase is the water system. I'm using this 22 gallon over the wheel well tank with this submersible pump and this faucet. When you turn on the faucet it activates power to the pump. The photo below shows my simple tank mounting. It will be secure, but easy to remove for cleaning. View attachment 86651
Thanks for your suggestion. I am using cam loop straps in other areas of this van project. I like having the ratchet action to tighten the straps around the water tank, but it might work well to have a combination of ratchet and cam loop straps.Hey, if you want an easier to use and less intrusive type of strap, try something like theses cooler straps: 8′ Length – Cam Loop Strap – Cascade River Gear. We use them to hold coolers and dryboxes to the whitewater raft frame. Super strong and easy to use. Or make. I've been making my own for decades.
Looks Good 👍This week I was mounting the propane vault. I anchored it with 1/2 bolts through the base of the vault and van floor. It takes a 4 inch bolt to reach all the way. This is the final arrangement for the propane lines which is different than the youtube video I did earlier. View attachment 86949
Comparing to our use, it appears you are approximately trading solar for propane.Propane allows us to utilize our van with a minimal 12v energy draw. I think we could sit for up to 3 days (average estimated time to about 20% SOC) without charging our 250Ahr AGMs. How many days really depends upon the environmental conditions (weather).
