I'm guessing if an item is on sale discount codes are removed, i should have read all of proeddie's wordsStrangely the WillProwse coupon code doesn’t work for me for the cheaper 100Ah Lithium.
MrNomer wired all our outlets except the one that powers the fridge, freezer and charger to run off shore or inverter. A very convenient feature.While waiting for "stuff" I'm working on an auto-transfer switch so when the inverter is switched on, some outlets in the van (microwave, kitchen counter, outlet by the slider door) will auto-switch to inverter power. When the inverter is off, the same outlets will be on shore power....
How do the outets know when they are on shore power and when they are on inverter?MrNomer wired all our outlets except the one that powers the fridge, freezer and charger to run off shore or inverter. A very convenient feature.
This is also how I do it. It adds a layer of safety and reliability.In my design, I decided on separate inverter and shore power charger, so that's not included like it is in the charger/inverter combination unit.
Actually, it sounds like he's using (2) 3 way switches to make a DPDT switch...MrN says it's the poor man's way of making a DPST? switch with two SPST switches. All I understand is that there are two toggles side by side that are flipped together. One way shore power works, the other way inverter power works. However, in addition, we turn the inverter itself on and off each time it is used because of its parasitic draw.
It will be interesting... I'm trying to pack 16 oz of sardines in an 8 oz can ! Tape measure says it'll work....For some strange reason, I applaud your choices. 😁
Hi Eddie,Gary,
I appreciate your thoughts on this...I was going to get a commercial transfer (relay based) switch.
Most are wired with AC plugs and outlets going to a DPDT relay, so you plug one plug into a shore power outlet, another into an inverter, and the outlet side provides power. It looks like the pictures and instructions show the green wires all tied together and the black and white are (relay) switched.
My plan was to replicate that (with a $26 relay) in a box and some cords.
According to the Renogy 2000W Inverter manual, "NEUTRAL and GROUND are bonded inside the inverter to comply with the National Electric Code (NEC) requirement that any AC source must have a neutral to ground connection. "
So my take is that I can safely switch just white & black, and tie all the green wires together.... am I making sense to you?
Hi Eddie,Gary,
A few questions...
I'm used to getting home from a ride and if I'm not going out for a few days I plug in shore power to run the Engel fridge on AC and charge (my old AGMs).
It seems like I won't need to do that very often, because with 300Ah and Lithium it should sit stand-alone a lot longer.
I got the Renogy 20A charger (no labels say Renogy so I think they just buy it and sell it). It is sold specifically for their LiFePo batteries. Seems like it runs very warm. Amazon, so it's returnable...
With the Victron unit, I guess you don't set a lot of parameters, just tell it it is Li and away it goes. Charges to full, and then just sits there. Once I set it for LI, when I plug and unplug shore power, will it remember the mode I set so I don't have to use Bluetooth once it's set up?
If my math is correct and I run my 300Ah down to 20%, then I need to refill 240Ah... 17Ah at a time, that would take 240/17= 14 hours? After that I'll maintain at 100% (which I guess isn't optimum but not too damaging)
My concern with any of these chargers is that I'm used to plug 'n charge, unplug 'n go... repeat. Hoping I can do the same. I'm not big on watching meters all the time, but I'm sure most people with a battery monitor and a new LI setup do it!
I actually DID connect the Renogy 40A B2B unit (set to 50% charge) to a 30A ham radio power supply and it charges nicely. That may be my go-to solution, or the Victron seems like an equally simple and not too expensive way to go (if it's set-it-and-forget-it)
