Hey, where is the protection fuse on the shunts power lead?Yep...yep
If you think about it, the max charge voltage of an AGM battery can actually easily reach 15 volts in the winter if the charging system is temperature compensated correctly, and fall well below 12 volts when under load trying to power the heater at night if the van interior is very cold. Both scenarios are kind of a pain.Reading this, a past item came to my mind. Like @proeddie I am an AGM guy so I have no experience with Lithium in my vans. The past item that twigged my mind was the 14.7 volts & the Maxxair fan voltage sensitivity. I contacted the manufacturer directly & was told nothing over 14 volts.
So now I am wondering for those who have had Maxxair fan “beep of circuitboard death” occur what type of batteries are they - Lithium??
I have had 2 vans bith with Maxxair fans and AGMs and no solar (another possible source of above 14volts while charging), but so far no issues with the roof fans failing.
Good Luck with your changes @proeddie I do not have Renogy anything, but when I buy electrical equipment now I try to make sure it is compatible with 12v & 24v and FLA, AGM, & Lithium. I prefer user programable equipment where I can set the charge profiles up.
I was being somewhat tongue in cheek. All the talk of protection would dictate that a power lead connect to the battery should be protected at the battery terminal.The manual doesn't say anything about a fuse on the small red wire... is that the shunt's power lead to which you are referring?
That helps 👍If you think about it, the max charge voltage of an AGM battery can actually easily reach 15 volts in the winter if the charging system is temperature compensated correctly, and fall well below 12 volts when under load trying to power the heater at night if the van interior is very cold. Both scenarios are kind of a pain.
This was one of the driving forces for me to build 24 volt (and higher) systems and use regulated 13 volt for the 12 volt appliances.
There are more reports of the circuit board issue happening in the "auto turn on" versions of the fans then in the more simplistic models if that helps any.
AFAIK, it does not matter if you use the "auto turn on" feature or not, what matters is that the circuit board used in that version of the fan is more sensitive to higher voltages than the lesser version.That helps 👍
I never use the “auto turn on”
Maxxair were very interested in knowing if I had solar. IIRC the voltage parameters they told me were between 10.6v & 14.0v.
My Rolls AGMs work out to 24mv per C temperature off the standard 25C
My Van AGMs see above 14v when charging from the PM alternator (direct cable from the started battery). I almos exclusively charge my van AGMs by alternator. Fully charged & a rest & disconnected from the van alternator I would expect them to sit around 13v.
I have thought about it in regards to the Maxxair & above 14v of the van alternator & I cncluded it would ge a very weird operation for me to be driving down the highway alternator charging with the Maxxair fan hood up with the fan turned on & running. 😳. It is possible, I just do not use my van/fan in this manner.
Thus I concluded, why Maxxair asked me about “solar” - which I do not have on my van. If I had solar & the magic of set it & forget it I can totally see running my Maxxair & the solar “kicking in” @ 14.7volts. And then the systems voltage is over the 14v max while the Maxxair fan is running.
I’m a believer in the 24v system and converter to run 12v 😁. I currently am doing ok with the 12v setups I have, but if buying electrical components now the 12v or 24v (like the Victron MPPT controlled is user set & capable of both) are more attractive to me as are equipment that is user programable that can handle all types of battery chemistries. This way if I am in @proeddie position of swapping things out I can keep my “multi voltage or chemistry” equipment. I think the key is in user programable.
It is why I like the Kisae DMT1250. I believe @GaryBIS purchased one of these
DMT1250 – Kisae Technology Inc
www.kisaepower.com
( -30 C) is a common winter temperature in Canada and many parts of the US.My Rolls AGMs work out to 24mv per C temperature off the standard 25C
Thanks!Check eBay as well as Prime. My best deals on Renogy were via eBay. Amazon for most of the other stuff (or if I needed the part yesterday).
I went all Renogy (not the solar panels) and regret picking the inverter/charger since I rarely use shore power. I don't regret going with 2kw inverter as I don't use propane. I slightly regret not going with a third battery and 3kw, but in practice 2kw does it all including running my power tools as I built out the van.
A single 200ah lithium (not Renogy) might be cheaper that 3xAGM and a whole lot easier to wire and stash somewhere in your van.
W/regard to parallel vs. series, do a little more research on the internet, maybe pay a visit to "Diysolar.com"
Finally, that combo Renogy charge controller will float charge the service batteries when the house is full. But you are right, it does cut the alternator current 50% when solar is present. Easy enough to bypass with a relay on the solar feed in. You say you will be driving a lot and then staying put for 2+ days. Seems like the combo will work fine for you if 50A output were sufficient for your needs.
Hmmm….food for thought! I previously stated I didn’t want to “engineer” system with separate charger, but the Renogy option might work. Cost would only be slightly more if I went with 1 or 2 Li batteries (and a standard inverter), but overall might be a good option.Current options are the Renogy 20A plug in charger (cut off the clips and use lugs), the Powermax PM4 55A
I used a non Pure Sine Wave (Harbor Freight 2000W) inverter for 6 years... microwave was a bit noisy but worked fine.. Keurig coffeemaker was happy, induction cooktop was a no-go (but I usually use butane).Hmmm….food for thought! I previously stated I didn’t want to “engineer” system with separate charger, but the Renogy option might work. Cost would only be slightly more if I went with 1 or 2 Li batteries (and a standard inverter), but overall might be a good option.
Question: how would the system handle the AC current? I assume the higher voltage would “win”, correct? Any other issues/concerns?
WillProwse coupon code gives you 10% off renogy batteries.As far as batteries, The Renogy 100Ah Bluetooth batteries are on sale at $499 plus another 5% off... 100Ah AGMs are about $300... (They were $150 when I got mine in 2015)
I could find no way to get 10% off with the willprowse coupon codes... I did see 5% at one point, currently no willprowse discount apples (maybe because it's on sale (up from $499 to $519))WillProwse coupon code gives you 10% off renogy batteries.
That’s what I was thinking. Easy enough to wire up while I’m at it, and it gives me another option with an extra switch (100%, 50% & 0% output).Mr B, I think the LC wire would be useful to limit the load when in traffic, idling, etc...
Yes, installing switches on both D+ and LC wires gives you max control, which is always a good thing. I did that to mine and I use them both.That’s what I was thinking. Easy enough to wire up while I’m at it, and it gives me another option with an extra switch (100%, 50% & 0% output).
Strangely the WillProwse coupon code doesn’t work for me for the cheaper 100Ah Lithium.
