Thinking about the AGM to Lithium upgrade for my 6 year old (but still working OK) 100Ah batteries. All new items from Renogy.
It appears I will not be able to use my Battery Doctor, Powermax RV converter/charger, and batteries.
Plan is for (2) 100Ah LiPo4 (the basic ones, not smart) batteries, and a 40A/20A DC to DC charger (and using the LC input to charge at 20A most of the time). Plus the 2000W PSW inverter/charger.
Questions:
I'm trying to figure out a few last details...
the specs say that LiPo batteries charge up to 14.6 or .7 volts. Being an AGM guy, I'm wondering about how much impact that much voltage (14.7V) will have on all the 12V items that are in the van (TV, Ham Radio, Scanner, Maxxaire, radio, lights, USB sockets, etc.)
They all expect about 13.2V from a standard battery, so 14.7 is about 11% over voltage. Has anyone had any issues?
I'm not thrilled with the size of the 2000W Inverter/Charger. I like the built in transfer switch, but can't seem to get info on the details of this unit, like...
- does the fan run if the batteries are charged and you're on shore power?
- does the (included?) remote switch have to be on in order for the transfer switch to work?
-the optional remote display meter for the Inverter/charger... is it just a copy of the built in display? Does it show SOC, etc...?
If I give up the combo unit and just get the 2000W inverter, I should be able to get their basic 20A charger to charge while on shore power, right? I'd lose the transfer switch but that's not a big deal for my use.
Now, I just get home and plug in to shore power if I'm not using the van for a few days... I don't think about full charging (which I guess is not good for LiPo)... I don't think about anything... it just works. Will I have to spend my diminishing brain cells remembering to check the meters all the time? Now I have a simple volt meter readout... it tells me if I'm fully charged (which is OK with AGMs), or low on charge. Easy...
Thoughts welcome - some items on sale NOW !
Questions:
