Just size down your bit from the screws, I think it was an 1/8" bit that I used. The screws that come with the vent are already stainless so used the supplied ones. I have 2 fans, the back one I didnt screw into a wood frame and it has held on for almost a year. The front fan I installed a few months later and adjusted my install technique.
Both fans have butyl tape as the gasket and Eternabond as the exterior sealant. I highly recommend the Eternabond, super easy to install, looks good and holds up well; compared to dicor lap seal. Just my 2 cents on that one.
You will want to build up the butyl tape to be taller than the ribs of the roof. And if using Eternabond tape, I recommend getting the 4" wide stuff. The 3" I used was a tad too narrow once it contorted around the dips in the ribbing, so i had to double up the 3" tape.
Good luck, super easy to do and makes a difference in temp during the summer time.
