Me too! The only hiking I ever did was in Malibu, which wasn't very high. I have no idea what 4000m would be like. Will bear like it? I'll wear him in a bag on my chest when we go hiking.Lola, I'm looking forward to your 4,000m test run.
What?The Metric system is based upon the most abundant chemical compound on the planet ,,, H2O;
He’s a chihuahua so half the journey he might have to be carried, but he’s a trooper. He likes kayaking.Our van has never seen elevations that high but we frequently crest 10k by foot along with our dog, Koya. Hence the name MTrun. We might be huffing and puffing by the top but this girl is happily waiting for us. I bet Bear will love it too.
Bears will like you. Bear will not like the bears. Take two cans of bear spray. One for each: one for youMe too! The only hiking I ever did was in Malibu, which wasn't very high. I have no idea what 4000m would be like. Will bear like it? I'll wear him in a bag on my chest when we go hiking.
..Bear only needs to be a couple steps faster than Lolaeliz to maintain his stealth. Cute little morsel, that Bear, is he not?Bear is pretty darned good at stealth.
1M x 1M x 1m = 1M3 fill it with water & the water weighs 1 Metric Tonne or 1000kgs 1000L in a M3 volume 1L of water weighs 1kgWhat?
As I have said many times in the past, these gasoline heaters (and most diesel heaters) cannot be adjusted to stoichimetric combustion without a combustion analyzer. Even with the CA, they cannot. The Afterburner control may assist but how would you know without that flue gas analysis? The same goes for propane heaters.This may open up the discussion to "I told you so" or "Russian clone" or ...but I am still working through my elevation issue. The initial email that I sent was followed by some good back and forth with the company and they were having me take some measurements and run some tests. The eventual conclusion was that when "high altitude mode" was started the pump should slow down the fuel delivery and I should be able to hear the reduction in the sound of the pump. In practice however the pump slowed A LOT, as in it just stopped. They were bench testing to look for a fix.
This is the less encouraging part of the story. I stopped hearing back from them. I am confident it is a real company so I didn't think they just disappeared like some ebay seller can do but why were they not replying. Maybe because the gasoline Bison is not a big seller? They have larger customers to help? I don't know. Today I called and found out that they are having trouble with the control unit on some of the heaters. There is no real fix and there are no gas units to replace them with right now. They offered to send me a diesel unit and an aux tank or I could wait until January when their next gasoline units are expected. So I am waiting. Right now it works fine at lower elevations. I just might be out of luck if I try and camp over 6,000 or so feet this winter.
Was I duped? Maybe. Won't be the last time.😜 I will stay optimistic and wait for January (which will come just after April?)
I'm no expert, but I was under the impression that at least some "automatic adjustments" are just simple barometric algorithms on the fuel side. Nothing fancy or particularly accurate. I think that's the case for my diesel Chinese knock-off with the blue controller. It has a barometer-altimeter, but I haven't taken it high enough for a real test yet.As I have said many times in the past, these gasoline heaters (and most diesel heaters) cannot be adjusted to stoichimetric combustion without a combustion analyzer. Even with the CA, they cannot. The Afterburner control may assist but how would you know without that flue gas analysis? The same goes for propane heaters.
Suck it up buttercup, I think you just got screwed.
I would invite any manufacturer to reply on this thread with their method and proof that their product will manually or automatically adjust for altitude and stoichimetric combustion, with actual full video of the process with an analyzer.
How would you even be able to tell what the combustion efficiency is without an analyzer? Most of the marketing claims around these heaters rely on the fact that very few folks have access to a combustion analyzer available to dispute their marketing claims. Does not matter what 'empirical claims' anyone makes, just claiming it works is nothing more than a fart in a hurricane. Nobody knows who done it.I'm no expert, but I was under the impression that at least some "automatic adjustments" are just simple barometric algorithms on the fuel side. Nothing fancy or particularly accurate. I think that's the case for my diesel Chinese knock-off with the blue controller. It has a barometer-altimeter, but I haven't taken it high enough for a real test yet.
I hear you, but I won't need to measure combustion efficiency to see if my heater performs satisfactorily at high elevation. We will see ...How would you even be able to tell what the combustion efficiency is without an analyzer? Most of the marketing claims around these heaters rely on the fact that very few folks have access to a combustion analyzer available to dispute their marketing claims. Does not matter what 'empirical claims' anyone makes, just claiming it works is nothing more than a fart in a hurricane. Nobody knows who done it.
I, of all people, should have known better before I invested in such an expensive heater (Webitcho). But to be fair, and I did not know this until I had already received the unit, deep in the manual, Webasto warns their unit will not give satisfactory performance above 2k ASL.
AFAIK, Webasto and Espar are the real deal. Chinese heaters are clones of those (all diesel so far). Russians are either doing their own cloning, or reselling Chinese clones. Somehow the Russians are offering both gas and diesel versions. Bison and VeLit are rebranded clones; Russian and Chinese, respectively, I think. VeLit is definately doing modification, not sure about Bison.I find it implausible that so many companies are making their own diesel/gasoline heaters. Im inclined to think that there bison, webitcho, etc are all using the $100 Chinese heater and making minor modifications if any to them and adding their own badging.
Velit, if they wanted to, could easily take their unit to high elevation with a proper combustion analyzer and video camera to prove the claims. Highly unlikely they will even do that. If they don't even own a proper combustion analyzer, what have they based their marketing claims on?I hear you, but I won't need to measure combustion efficiency to see if my heater performs satisfactorily at high elevation. We will see ...
Hi MSNomer,I have no idea what these mean, but it looks like they are trying. (Magnifier button is my error)
