1 - 2 of 2 Posts
Has anyone know how to alter the back up camera so it can be use to check the rear while in a forward gear? Example being to check your trailer load/tires while traveling.
I did a very extensive write up on how to do this several months go. Search the archives and you should find it.
It's very simple. Basically all you have to do is ground the wire that feeds the camera (I just put a dash switch on the center console).
If you can't locate it let me know and I'll dig it up for you.
1 - 2 of 2 Posts
