1 - 8 of 8 Posts
Discussion Starter · #4 · (Edited)
Air conditioner....its a must for me.....this one does not have temperature sensor which I miss
On outside the hole is bigger than air conditioner
It rest on right hand brackets.....brackets take the weight....use alum either straight or right angle on sides to cover open areas ...screw them down and tape with alum tape
Inside I have piece on bottom to angle conditioner down....top angle alum with piece wood to wedge it....wood is screwed to alum
2nd air conditioner put in....no flex in this one
Discussion Starter · #5 ·
I use ramps to raise front end to tilt air conditioner....also
Discussion Starter · #6 ·
Oh yeah ...i cut 3 L brackets about 1 inch wide. from L angle alum and used those with screws into front top of air conditioner....make sure u do not damage stuff.....i used short screws.....hard to see they are under alum tape
Discussion Starter · #7 · (Edited)
2nd trip....still learning controls
2 air conditioning...higj &low
Or 2 fan....high & low
Either air conditioning or fan
Put it on low air conditioner and then adjust temperature control to where it cuts on and off which is comfortable to u.....thats what's working...much prefer digital setting
Tokyo.... ballgame so bright cannot see air conditioner above tvl
Discussion Starter · #8 ·
per u-connect 602.1 miles / 28.7 miles per gallon
I picked my spots for gas. $2.89 9 ...saw some @ $3.09
filled up this morning where I was getting $2.89 and Thursday is considered weekend $2.99 9
more greenstone
1 - 8 of 8 Posts
