I think he was asking if you got a different offset for the front wheels different than the rear wheels?? I think you replied "yes", but I'm confused now....? LOL Are all four of your wheels the same offset?Did you get a different offset on the front? Looks like the front wheels are sticking pretty far out of the well?
May I ask what size tires you have on the 17x8 Ultra's and did you have hub rings installed (from where?) or have to trim any plastic for fit? I am considering this wheel..I'm running chrome 17 x 8 Ultra Toils and I love them, too!
Did you go with Koni FSD shocks AND struts and what do you think of the upgrade? View attachment 60248
Hey Tex,245/75/16. 16x6.5.
Yes they stick out a bit further front and rear, definitely a benefit.
There is no lift and although I considered it (body lift), I think its a bad idea as it raises the CoG.
I will however do the axle "cut and raise".
Self levelling air bags waiting to go on.
Wheels from Summit Racing
My wheels came with hub centric rings and I'm running tires that most of you won't be able to since my van isn't much heavier than a normal SUV (5,000 lbs). They're Nokian WR G4 255/65R-17 with a 2,601 lb load rating @ 51 PSI. They're 3 Peak snow rated all season tires, quiet on the highway, low rolling resistance for better mileage, and have kevlar in the belts to prevent punctures on fire roads. No rubbing with no trimming, too.May I ask what size tires you have on the 17x8 Ultra's and did you have hub rings installed (from where?) or have to trim any plastic for fit? I am considering this wheel..
I ordered the Billy FSD B6 front struts and rear shocks from Shockwarehouse, just waiting for delivery. I am going to replace all four when I install my Van Compass front 1.5" lift. Just trying to be patient while I await, but it's difficultDid you go with the FSDs? Front and rear? If so what do you think about them, any improvement in ride quality? I'm ready for new shocks and not sure if I should go with the konis or some billys, or with fox in the rear. All I do know is I wish my van rode better than it does!
I'm confused- Did you order Bilstein B6 or Koni FSD struts & shocks?I ordered the Billy FSD B6 front struts and rear shocks from Shockwarehouse, just waiting for delivery. I am going to replace all four when I install my Van Compass front 1.5" lift. Just trying to be patient while I await, but it's difficult...
Bilstein B6 struts and shocks. Not FSD's sorryI'm confused- Did you order Bilstein B6 or Koni FSD struts & shocks?
I'm not sure - It wasn't an issueHey Tex,
Did Summit Racing have hub rings for the 84.1-78.1 difference in the wheels?
