When a did my previous conversion I attached birch paneling directly to the ceiling ribs after insulating and noticed on cold mornings a strip of moisture appeared on the paneling directly below the ribs. If I put a double sided exterior foam tape on the ribs before installing paneling will this prevent the condensation and do I need to put rubber washers on the sheet metal screws also, any ideas? Thanks
