So I got my floor mostly finished. 1/2 insulation board and 1/2 birch ply. Followed a lot of the advice here. Looks great, fits well. I ran three 4' sheets of ply horizontally to span the 12' space, two have one of the factory tie down bolts, the other (middle) has two. Ran the insulation opposite so no matching seams.
I haven't glued the ply to the insulation but plan to use Great Stuff Construction Adhesive. There's a good amount of flex at the seams and some of the edges (sliding door edge especially). I'm hoping glue and a ton of weight for a day or two resolve much of it. If it doesn't, I'm curious about the following: use a router to recess a few narrow areas where the ply meets. Then, fill that mirrored recess (spanning both sheets) with a nailing plate, fastened with screws.
I'm using vinyl plank flooring that should tolerate that well.
I'd really like to avoid screws/bolts through the body of the van and wasn't sure if someone had tried this method before. I don't have any joining tools, so I'm a little limited on making the ply a 'single piece'.
