1 - 10 of 10 Posts
I put a heater in the back and had to add antifreeze.
It's called "Celsius" Extended Life Antifreeze/Coolant.
This stuff is clear and is compatible with ANY colour antifreeze/coolant.
Suitable for use in any car or truck with alluminum and other metals.
No colour is not safe for spills as it looks like water!
So basically we can use a universal type of coolant?
Well after further research I found out Chrysler started using OAT (Organic Acid Technology) antifreeze in 2013 and it must meet Chrysler Material Standard MS-12106. So far it seems to be only available at the dealer.
Disregard my posts, Looks like I made a mistake. Have to get it flushed out now.
Thanks for the info.
An OAT not Mopar can be bought at Autozone. Check before buying Mopar at Autozone because it's usually not the part number or an OAT antifreeze. Regular Mopar says 5 year OAT says 10 year
Yep, better safe than sorry. I needed some more anti-freeze to fill the additional coolant loop supplying our IsoTemp hot-water heater. Given those very specific specs in the owners manual and potential warranty concerns, I ended up buying Mopar 10-yr OAT from the dealer.
1 - 10 of 10 Posts
