For those who may be planning on a window install, here's some pics of my project.
Mission: CRL windows to be installed at the back corners, both sides... 159wb PM
Progress: One side done!
Ribs removed... I noticed that on pictures of OEM windows, the back rib remains and the glass is in two pieces. CRL glass is all one piece...7' long!
I made a template from 1/4" plywood. I cut it the size of the window glass, then transferred measurements to cut the hole. Figured it would be easy to just attach the whole template to the wall of the van and cut along the pattern. Worked great. Window fit on the first try.
It was worth using a $20 piece of plywood to create a solid one piece pattern.
I drilled two 1/4" holes in center area and bolted the template in place so it wouldn't move while cutting.
It made the job a lot easier, and the shoe of the jigsaw rode on the plywood, so no scratching of the paint. The other side will use the same template (other side of plywood facing out- same pattern) and I just need to cut a piece off to fit over the track for the sliding door. Medium TPI metal cutting blade worked well.
I did remove and grind about 1/16" at one end of the top to match existing window, then painted on a thin coat of paint to avoid rust. Not sure if needed, because the seal is pretty tight, but can't hurt. Tough to paint the edge, but I got a thin coat on.
Inside view... window in place
Outside view
When I started researching windows, posts on the forum help me plan my install. I appreciate all who shared their work!
Other side? tomorrow!
Outside view
