So this post is for those of you who want storage (specifically mountain and road bikes) under a bed platform. This means you need a clear space under the bed for handle bars etc. I wanted to go aluminum for the span but those bed kits are way expensive. I tried some local welding shops and their quotes were worse- like 1000+. So I found this idea and ordered these Reese straight loading ramps- cut the three inch tongue off and they fit perfectly on my 2 by 6 bed rails located 35 inches off the floor. The aluminum was harder to cut than I thought- had to get an edge grinder. Otherwise not too difficult and only 200$ for the two pair. If I was shorter the bed would be done but at 76 inches tall I will be adding 18 more inches supported by a cabinet and my wife and will sleep long ways.
https://www.amazon.com/Reese-Explor...488677860&sr=1-4&keywords=reese+loading+ramps
