A fellow expediter I know went through a lot of frustration with finding a simply, elegant window shade solution. We put our heads together and came up with the following.
It's just corrugated cardboard boxes, edge wrapped with gorilla tape (duct tape would work too) and covered with those cheap foil sunshades you get at truck stops spray tacked to the cardboard. It ain't rocket science, people. The windshield shade is two pieces that overlap for no gaps.
The "trick" part is that the doors have a channel at the base that perfectly holds the shades in. The windshield also has this at the base, but I just use the sun visors to hold it in at the top.
The other "trick" part is that the window shades fold and store perfectly in the PS door pocket thingy, and the larger front window halves fit the slot shaped area right next to them. Nice.
You'll also notice that I've removed the front seat. This was literally a 3 minute affair involving only a 17mm socket. The only downside is that the airbag idiot light is permanently on, because the seats have 3 connectors: seat belt, airbag, and weight sensor for the airbag.
Kip-on-Truckin'
Kip-on-Truckin'
