I started applying Dynamat today--25% coverage. After applying the Dynamat to the centers of the roof sections, I tapped around with a stick. I discovered that the outsides of the panels were still quite live. I applied one 2.5" x 18" piece to the outside "recess" in the second panel from the front (above the door). The effect was dramatic not only on that side of that section, but also on that side of all three other sections. I ended up adding similar pieces to both sides of all sections.
Now I want it to rain so I can listen. :laugh:
BTW, I got 36 sqft for about $145 on Amazon. It is very easy to apply and I cannot smell it at all. Because the surface is essentially flat, I can use the edge of a short piece of wood to press it in place instead of buying the roller.
