2014 1500 Promaster van. I put in a house battery, Lifeline 135AH, and circuits for lights, a plug in cooler and a propane heater when I got the van in 2015. Battery charges off the alternator, with an isolator in between. I had a local shop hook up the isolator and do the wiring runs from it. As soon as this was completed the battery light would come on after a couple minutes of driving, usually only after sitting overnight. I could stop and restart the van and the light would go away and stay away. I had the shop check it out and they swore everything was working normally. I've been driving the van for two years, stopping every morning after a couple minutes to restart after the light came on. Finally a few weeks ago the battery light started coming on more frequently, and not going away. I had a different local shop look at it, they said the alternator was bad, ordered a new one, put it in and it didn't work. They suggested I take it to the dealer, which I did, they replaced the alternator and it worked. Whew.
The dealer's diagnosis was that the isolator is somehow responsible for the alternator burning out. I'd guess this is correct since the whole battery light episode started when it was installed. My current thought is to install some solar panels and a CTEK 250s controller. I like the idea of this controller because it will feed the starter battery as well when the house battery is topped off, which should take load off the alternator and hopefully prolong its life. I have a friend with a Chevy van who is using the same system and it's worked well for him, which is where I got the idea.
So what say you Promaster electronic whizzes, Yea or Nay on my ideas?
