...replace the fan with an AC unit....
Are you saying that it is best in terms of airflow to have just a fan or A/C, or are you saying that I might not have the room to fit all three (fan, A/C, solar)?
...I would put one as far up front as would fit good and the other as far back as would fit good... If you want them to work together for air flow, what better way is there? The solar panels can be bought to fit
That's what I was thinking...
I put the Maxxair (4500) at the back end of my roof... The back location allows for air to be drawn from the front windows all the way thru the van to the back...In the back you do have to contend with the hill-and-valley roof.
Thanks. You described my "phase 1" of HVAC: just get the air flowing. I bought the roof adapter that Hein sells so ridges won't be an issue. It'd probably be easy to install a screen on the front windows to keep the bugs out.
For phase 2, I'll be buying the A/C in the next couple months (or sooner if the heat gets me!).
...I missed the vent's use while off grid especially the passive venting and rain use...
1....Roof ribs limit where holes can go but not for solar panels.
2....Solar panels can be sized...should be easy with EXT length.
3.Coleman Mach 8s...
4. Decide if you want MaxxAire venting or blowing in a certain area like over galley or bed.
5. Make cardboard cutouts...
What do you mean that you "missed the vent's use"? You didn't have it and wanted it?
1. "Roof ribs limit..." good point!
2. Good to know on sizing the panels.
3. I'm looking hard at the Mach 8 and 10. RD recommends them.
4. So you're an advocate of having the fan and A/C?
5. Working on floorplan now.
Thanks for the help! Do you guys think it's a good idea to have the fan and A/C, or should I just get one or the other? My plan on getting both was because I assumed air had to be pulled out (fan) as well as air coming in (A/C). Is that correct?
