Hi everyone,
Just wanted to post this and see if anybody knows the answer and/or can confirm what I am being told, as I am getting conflicting information and I would hate to burn my van down....lol.
I'm in the process of setting up the following:
Interstate 31M-AGM Sealed Deep Cycle RV/Marine Battery
(2) 100 Watt Renogy Solar Panels going through their "Wanderer" Solar Charge Controller.
This is an independent system of the starter battery and engine/alternator.
The Renogy Wanderer has 3 options on the front of the Charge Controller to select the type of battery you are using: Sealed, Flooded or Gel.
I called Renogy customer service and asked, since I am using an AGM battery, which option should I select. I was told to use the "Gel" setting on the Charge Controller.
I felt the person answering my question wasn't quite sure of their answer, so I called them again two days later and asked the same question. The person said that I needed to call the battery company and ask them if the battery is able to equalize or not. If it IS able to equalize, then I should use the "Sealed" option. If it is NOT able to equalize, then I should use the "Gel" option.
So, then I called Interstate and after going through 3 people, I got a guy that sounded like he knew what he was saying. He said that the 31M-AGM battery is able to equalize if it is used by itself, but if it's in a battery bank of multiple batteries, then it cannot.
Sooooooo, since I am only using one battery, I will select "Sealed" on the Solar Charge Controller, right?
Thanks for the help!
John
John
