Hello all.
I've been reading and reading and now I'm slightly less dull than I was before. And my head is spinning and I still feel stupid.
I'm going to need a/c and I don't want holes in my van. Reading brought me to the most efficient portable a/c, 12k btu with dual hoses and a variable speed compressor. Runs off the Honda 2000eu, startup and all.
Here:
https://www.practicalpreppers.com/a...units/climax-v12-portable-ac-unit-detail-view
With 2 agm Lifeline GPL-L16T wired in series to fuel the beast.
Here:
https://batteryguys.com/products/li...=cpc&utm_source=googlepla&variant=32270665156
And I thought I wanted solar for everything above, until my reading made me realize I have a potent 220 amp alternator that, because I drive a lot and sit around little, will probably suit me better. Except I'm not clear on the details of using my alternator to charge the batteries above but I think I need this Sterling Battery-to-Battery Charger 12V-12V 120 Amp Input with a bunch of little gadgets in-between to make sure it all works as it should.
Here:
And of course a converter of some sort to plug the beast into, or whatever that thing is called that everything plugs into.
Any thoughts? Will it work? Is there a better way to proceed? I know, I know, a rooftop a/c is already designed for just this scenario. But maybe for my particular case this will work better...
Here:
Here:
Here:
