Had anther failure, so I thought I'd document it here for posterity. Cracked flywheel (yes, it's correctly called a flex plate). There was an instance of this happening on this forum in the early days of 2014, but unless I missed it I'm the only other one.
Story:
Driver cruising down the road lightly loaded. Suddenly engine hits the rev limiter. Won't restart because it won't spin, because the flywheel is cracked. It did give some warning as a few days earlier the driver complained of a rattling sound. I looked and thought it was the fan assembly, which does have some play in it and can rattle.
Confirming the problem was easy. There's an access panel at the bottom of the bell housing, and I could spin the flywheel with my finger. Plus I could move it side to side with a screwdriver. Flex plate failure has happened to me once before on a 60s vehicle, and research turns up that this was a common problem when the 62TE trans was introduced in 2003. I've had the engine out of this particular van, so I was was worried it cracked because of something I did, or some torque spec I didn't follow. Not so, as the bolts and area around the bolts was fine, it was the rest of the flex plate that cracked. Conclusion, confirmed by other mechanics, is that flex plates just sometimes fail.
Brand new OEM flex plate is $70 from the dealer. Can be had online for $50. Junkyard flex plate is $25. I went OEM.
While a simple fix, it basically involves removing the transmission. This books at 5-7 hours, but a friend and I did it with a few special tools. In short, you simply:
Put the front in the air
Remove both axles, which means undoing the lower ball joint, using a long bar to pry down on the lower control arm after unbolting the knuckle from the strut. Also involves a big impact gun and what I believe is was 27mm socket for the axle nut.
Unbolt starter
Support engine (floor jack) support trans (floor jack)
Remove ps axle carrier bearing to block support (3 bolts, easy)
Remove upper trans mount
Remove lower trans mount
Remove bell housing bolts and 4 torque converter bolts
At this point, the trans can move away from the engine block with a decent amount of room to get the old flywheel out and the new one in. Torque to 70lbs at the crank. If you felt like it, you could remove the shifter cable and electrical connector and take the trans out altogether. Also, there's one sensor (output speed sensor) on the back side of the transmission near the bell housing.
This job was a pain because we were lying on the ground, but indeed it took about 7 hours in total. I could do it again in 5 comfortably. Overall it was more of a pain than a RWD vehicle, but no different than any FWD vehicle.
Overall, I relearned two important things. Modern cars are tough to get apart, but they go back together super easy. This is the opposite of the 60s/70s junk I'm used to working on. It's because a car that easy to assemble on the line is cheaper to build.
And I also re-learned that not much on the PM is different from 60s/70s cars. The flywheel looks the same, works the same, and is replaced the same as on something from the Johnson administration. The newness/scariness of new cars is all in the fuel system and electrical unicorns. But a starter is a starter, a trans is still a trans, a bleeding knuckle is still a bleeding knuckle.
Story:
Unbolt starter
