1 - 2 of 2 Posts
Anyone know where the filler spout is located to add gearbox oil ? I drained some of mine and need to add some.
In this old Fiat Ducato document You can see where filler spout is located.
It is in italian, but if You go at page 116 of the document You'll find 4 draws.
In draw number 4, the 1 is "tappo di riempimento olio" = oil fill plug
The other part translation are "interruttore retromarcia" = reverse gear switch, "tappo magnetico" = magnetic plug, "tappo di scarico olio" = oil drain plug, "differenziale" = differential, "cambio" = gearbox
http://www.giordanobenicchi.it/camper/IVECO-FIAT/Traccia%20Didattica%20Fiat%20Ducato_1-181.pdf
In this other document can be found some additional information about C546 (M40) automated version
http://fcconnect.co.nz/wp-content/uploads/Ducato-Robotized-Gearbox-M40.pdf
Beware that some fluids capacities changed over time.
1 - 2 of 2 Posts
