1 - 6 of 6 Posts
I'm about to start insulating the PM. I think I'm going to use Reflectix and Rigid foam board for insulation. I was wondering which material should go down first the Reflectix or the foam board? I was planning on using the 3M 90 adhesive. Any advice would be greatly appreciated. Cheers PM'sters
There are many good ways to insulate, but my opinion and that of many here: with polyiso rigid foam board, you can forget the Reflectix. It's only true benefit is reflective, and foil-faced polyiso covers that, too. Also note any reflective benefit requires an air space. Many folks using other insulation methods (Thinsulate, etc) forego reflective all together. As a newbie once myself, I initially gravitated toward Reflectix because it's readily available at Home Depot (etc) and it's cheap. Reading this forum helped immensely.
Others (I) would say NO it’s a waste of time and money but it’s your time and money so do as you please. If you have a half decent heater it will make no difference at all but if you need AC it might help a bit.
Reactions: RV8R
I would say the insulating the forehead is worth while because I can cook a pizza in that storage area if the sun is beating on it.
Van #2 2021 EXT
IMO;
Delete the Reflectix
Polyiso @ walls & ceilings
XPS on the floor
& I’m with KOV about the cab roof (won’t help heat retention much with consideration of all that glass). Cooling - not sure as not the climate we are usually in.
edit; maybe if @GaryBIS was not so busy with his Backyard Dinosaur he would have the cab roof insulation cooling test results out by now 🤔
1 - 6 of 6 Posts
