A couple of sleeping bags or even some inexpensive queen or king size comforters doubled up would likely make a big difference. Hard to insulate all that steel framing in the back. Layer up over the top of it reduce the heat suck.
I'd love to isolate the cab, but the problem is my webasto is under the passenger seat and it pulls air from the footwell of the cab area to figure out what the temperature is. If I seal off the cab area wouldn't it be 95 degrees in back of the van and 40 degrees in the cab area, because the heater would never turn off. There's no way to reroute the air intake. I'm guessing if I bought the thermostat for the webasto I could maybe get around this problem????Try isolating the cab too. In our previous van we would hang a curtain across the cab area to try and minimize the amount of cold air coming from the front windows.
You could still hang a curtain but have it so the webasto vent isn’t blocked. The idea is just limit the amount of cool air coming into the warmed area. In our old van our heater was back by the rear tire but aimed at the side door, so we had to come up with ways to keep that heat from being lost to the front.I'd love to isolate the cab, but the problem is my webasto is under the passenger seat and it pulls air from the footwell of the cab area to figure out what the temperature is. If I seal off the cab area wouldn't it be 95 degrees in back of the van and 40 degrees in the cab area, because the heater would never turn off. There's no way to reroute the air intake. I'm guessing if I bought the thermostat for the webasto I could maybe get around this problem????
Hi,Vans have limitations that simply can't be overcome. At best a van has minimal insulation and an overwhelming number of places for heat loss. In colder climates your best bet is short term warm periods. If you want to sit inside all day you'll need a heat source running constantly and you should never open a door. But if you did that you'd have a real condensation problem.
Hmmm, I'll have to think about it. I could fashion something similar if I got a three foot hose that connects to the intake and wraps around the front of the seat through the area in between the seats. Maybe make it detachable so I can stow it out of the way until I really need it. Or, I could see if I can track down one of those remote temp sensors and see if that works...@Jlo11111
Heater under the passenger's seat, not for everyone, but it works for me. When I need to close the cab curtains I have this setup that puts the heater inlet and outlet on the cargo side.
is there any way to adjust the heat better? Thermostat?The heater made the cab too hot so I kept getting up to turn it off. So finally I just left it off:
There's an on/off timer. I still need to figure that out. Do you know if the esper / webesto heaters have a thermostat?is there any way to adjust the heat better? Thermostat?
