Do you have a spare puck light you could just connect directly to the dimmer? But after connecting the input directly to the wires, running to your puck lights that pretty much isolates it you could further isolate by going in the middle of your run of puck lights and disconnecting the first two or three and see if you can cut your problem area in half that way. For example, disconnect the last three lights from the chain and then try to power that section directly with 12 V.
