1 - 9 of 9 Posts
Hi all,
Busy adding some mopar coolant to the Van since it was a little low.
Does the Promaster not have a radiator cap? I could not easily find the main cap. I did add to the reservoir but on my other cars I used to have to add to the radiator aswell. Just checking to see if we only need to add to the reservoir.
reservoir cap is the cap
And don't bother adding any as long as it's above MIN. Its happy place is usually closer to MIN than MAX. It will always end up there no matter how much or how often you add.
2016 3500 ext-ht
And the $64k question is where does it go. Maybe Mopar antifreeze is like Wyoming snow. Just blows/circulates around until it wears out?
Poof!!
Poof!!
Even old radiators had a happy place. If you overfilled, it eventually disappeared and returned to its happy place. It just blows out around the pressure cap, I guess. When the PM engine is hot, the coolant level is up closer to MAX. Cold, it's back down near to MIN. They don't call 'em expansion tanks for nothin'. ;)
Discussion Starter · #6 ·
It was quite a bit below min. I add a little over Min, but thanks for the tip! And thanks everyone else on input.
2016 3500 ext-ht
OK, I suppose. With a new rad replaced ~10-15k ago under warranty, I have still used almost 2 gallons of premixed. Or possibly ???
Yikes, mine hasn't changed in the last 15k.
No signs of a leak? IIRC, there is a common leak spot somewhere on the engine. Try searching the forum.
I seem to recall it was on the lower passenger side of the engine but there was a thread on it quite awhile ago. Very difficult to pin down tho just a slow seeping.
1 - 9 of 9 Posts
