I am 6’ 1” tall and have never had a problem with this vehicle not being a high top. It isn’t like these vans are large enough to take walks in.
PS, PB, A/C, U-Connect with BU camera, WeatherTech floor liner
Electrical:
Two NewPowa 100-watt solar panels, panels secured to 80-20 channel mounted to OEM posts with custom made aluminum brackets, Newpowa PMW Charge Controller, Sam’s Club Duracell AGM Deep Cycle Marine and RV Battery, Group Size 31, GoWISE Power PS1003 2000-watt continuous Pure SINE Wave Inverter and 2 110 volt, GFI outlets, one at microwave and one above sink counter, WirthCo 20092 Battery Doctor, Battery Disconnect Switch, 15-amp receptacle at rear for shore power
Insulation:
2” to 3” foil faced Polyiso in side walls and doors, 1” foil faced Polyiso in ceiling, ¾” foil faced Polyiso on floor under plywood, Custom fit, reflective front window coverings
Ventilation:
Maxxair 00-04500K 10 speed exhaust fan with remote, side door window 25-1/4" x 16-3/4", Rear driver side: Arctic Tern Window 300x700mm with screen & shade
Galley:
Ruvati RVM4136 16 gauge 13” X 15” sink, 5 gal. fresh, 2 gal gray water, electric water pump, TruckFridge TF130, 12-volt, 4.6 cu. ft. refrigerator with freezer
Sharp microwave ZSMC0710BB, built in cabinets with pull out storage and door locks
Bed:
Full size (sleeps 2). Mattress is 6” natural latex foam with fitted cover. Cabinet storage above bed with locks
Toilet: No smell, composting toilet with urine diverter and space for all supplies.
Luverne entry step at side, swivel passenger seat, Amerex dry chemical fire extinguisher, Mr. Heater 4,000-9,000-BTU Portable Propane Radiant Heater, black out curtains for back windows, black out curtains between cab and galley, Lights under cabinets and in ceiling, entertainment center and TV. No holes were made in the van anywhere.
