This has been an amazing camper van that has taken me on some epic adventures. It is rugged and durable, well insulated and quiet, stealthy, and perfectly outfitted for any adventure. It has been extremely well cared for and has many years of life ahead. Well maintained with no mechanical issues. The plastic trim panels show fading from the Colorado sun.
Goodyear AT Adventure Kevlar Tires
Dual FanTastic Vents 7350 Series
Two 150 Watt Solar Panels (Zamp Solar Deluxe RV Kit)
30 Amp Zamp Charge Controller
Battery Temp Monitor
Lifeline AGM 12V 210 Amp Hour Battery
Four Shore Powered 120V outlets
12 Solar Powered DC Circuits
7 Dual USB Charge Ports
6 12V Outlets
NOCO 12V 2 Bank Battery Charger
150 Amp Battery Isolator
10W LED Floodlight
18W LED Light Bar
12W LED Garage Light
Seven 1W LED Recessed Lights
16W LED Strip Lights
Noico 18Mil Sound Damping
Recycled UltraTouch Natural Fiber Mold-Resistant Insulation
Flat Screen 19" LED HDTV
Kenwood DNX9990HD DVD Navigation System
Rockford Fosgate 400W 4-Channel Amplifier
Garmin Drive Assist Navigation 50-LMT
3 Camera (2 Rearview, 1 Frontview) with monitor/loop recording
Uniden Bearcat 880 CB Radio
Dometic Refrigerator/Freezer
Olympian Wave 3 Heater
20 Gal Freshwater Tank, Shurflo 3GPM Pump
Outdoor Shower with Zip On-Demand Hot water heater
EXPED MegaMat Duo Mattress 77.5"x52"
Removable Bed Panels
Removable Mercedes 3 Person Bench Seat with Seatbelts
Propane Alarm, CO2 Alarm, Smoke Detector
Removable Rotating Table
5 Large Upper Storage Cabinets, Kitchen with Bar Sink
Spacious Garage Area with L-Tracks (Holds up to 4 Bikes)
Notes:
Factory brakes will need to be replaced at some point. Wear indicator has not yet been reached.
Lifeline 210 Amp hour battery has been in service now for 7 years and will need replacing at some point. Holds charge at 12.6V and maintains power adequately.
Starter battery was replaced in Nov. 2022
Headlight bulb assembly does not hold bulbs securely and has been modified to work.
Front drivers side outer plastic door trim molding is loose on one end.
Van has a few scratches and a couple of small dings. Nothing you wouldn't expect given its age.
Van Tour Video
More Pics At Van Camper HERE
6 12V Outlets
10W LED Floodlight
18W LED Light Bar
Notes:
Van Tour Video
