1 - 17 of 17 Posts
Wife and I have been discussing/planning this for awhile, finally snagged a used 2018 Promaster 136" WB high roof and started the build. The weather has been less than cooperative lately. Will be working on it mostly on weekends, so it's going to take awhile.
58762
Right before driving it off the dealer lot.
58784
Current plan for the interior, but is subject to change
Discussion Starter #2 (Edited)
Installed a Maxxfan before the snow.
58763
Cutting a hole in the roof when it was forecast to start snowing later that day was stressful.
58764
Done in time!
58765
Maybe it was overkill, but I didn't like the idea of sheet metal screws holding it down, so I used stainless machine screws with locknuts.
Started installing the windows now that it's warm enough. Having a small space heater in the van is very helpful, both for personal comfort and for glue curing. The side windows are from vanwindowsdirect.com, their "half-slider van bunk window combo". They seem nice, but do not come with any instructions or screws for the frames.
58766
Template in place
58767
Center cut shear is really nice for the straight parts of the cut, used a jigsaw for the rest
58768
Needs a window
58769
Gluing the frame to the wall
58770
Finished window
58771
Both side windows done
58772
Now she has some windows
Not much progress this weekend, had a lot of other stuff going on and I wanted to get some skiing in. Got one of the rear windows put in. They are salvage yard finds, so they took a lot of cleaning, however they look unique. They have plastic frames and real glass, we'll see how the glass holds up, but worst case is we replace the panes with acrylic down the road. Snow and freezing rain are forecast tonight, so it'll be the first leak test of all of the windows.
58966
Frame clamped in place
58967
We'll decide later if we want tinting for the rear windows, they're clear right now
58968
Not typical a van rear window
58969
We really need to clean up the garage...
Discussion Starter #7
Is that window from a residential front door?
Not sure, we found two of those at an RV salvage yard. We assumed they were from an older RV or a mobile home, since they are just plastic frames, however the plastic was still flexible and not sun-damaged, so they can't be that old.
Discussion Starter #9
Got the rest of the windows in last weekend. In hindsight, I would have just gone with new windows all around, the salvage yard ones required a lot of clean up time. We're still undecided what we'll do with the sliding door, we're going to leave the upper part of it uninsulated/unfinished until we're closer to done and then figure out whether we want another window.
59434
Both rear windows installed.
59435
We like the unique look of the back
59436
The big window needed a more complex-shaped frame and more clamps
59437
Finished windows inside
59438
Finished outside (it's a lot harder to get stuff done now that sunset is before 5pm)
Now we can move on to insulation!
Discussion Starter #10
Haven't posted in awhile, lots of other stuff going on so we haven't progressed as much as we had hoped by now.
60936
Solar panels installed, we opted for two 170w units. They're installed closer to the fan than we planned, but the positioning was dictated by being able to access the mount holes and sliding door hardware.
60937
Just a test hookup to make sure the panels/batteries/controller worked
60938
They're pretty big panels...
Discussion Starter #12
Started on insulation finally!
60941
Used 2" polyiso with Great Stuff filling in the gaps, we still need to clean it up once it dries
Pretty! That is a lot of insulation! You are going to have both a quiet and very easy to heat van.
However all that sound deadener under the polyiso was a waste of money. The stuff on the wheel wells and any un-insulatable space is going to pay off great.
Hi, Supermoocow ... Questions about the arrangement of panels/fan on your roof ... a) What are the size of your panels? b) Do you think if they were placed sideways, it would leave enough room for a 2nd fan at the back? Or maybe there is already enough room .. looked tight to me but maybe the picture is deceiving?
If these darned recalls are ever resolved and I can actually buy my 136 (low roof) my plan is to try to fit 2 fans, one fore, one aft on the roof .. and maybe some panels as well (but I'd give up the panels for the fans if I had to or limit it to one panel).
Thanks in advance.
Two 100 watt panels and two fans would work. Suggestion: one fan and opening windows does move a lot of air. Perhaps instal one and see how you like it. We have awning windows at the back and side and one fan up front. It works great and we found we didn’t like the fan right above us in our last camper.
Discussion Starter #16
The panels are about 26" x 58" and would fit in the other direction, but may need a different mounting setup. Using simple L mounts with the pre-drilled holes in the panels did not result in good placement on the roof. (we wanted the mounts on the tops of the roof ridges to not worry about water pooling)
I agree with RDinNHandAZ, with the rear windows open and the front fan on about 4/10, you can feel the air flowing through the windows. We were also worried about the fan noise if it was over the bed. I think two fans in a 136" van would be overkill, unless you don't plan on having any openable windows.
Thank you both. Good to know I probably could fit 2 fans in plus a panel or two if I need to.
My bed will probably be along the driver's side but I am not yet sure if it will be further to the back or further to the front. It probably won't be directly under the fan in any event. If I have an opening window, it is likely to be an awning style double pane acrylic but I am not sure of placement yet. Would like two but with the slider and the projection of that kind of window, I am not sure I can put them opposite each other in that short a van. I really would rather have double doors instead of a slider but that is not an option unfortunately.
I used to own a Class B PW and the arrangement you both have worked fine in that RV - fan at the front and windows on either side of the back lounge/bed area. But I also had a/c so if it was too hot I just turned that on and never really thought about what was 'sufficient' or the best design for comfort and aeration, etc. if one didn't have that a/c.
I'd rather consider all this very carefully before I cut holes in an expensive vehicle than be sorry later so your info and sage advice is much appreciated. I have seen all sorts of placements of fans/windows in videos but people rarely discuss the actual airflow they get and how it works under all conditions etc., especially in really hot, humid, places, and what would also work best in cold conditions, and/or if cooking and/or showering indoors. I have also wondered if I could just use one full size fan and a secondary small round one mostly for exhaust purposes.
Panels are another story - if I have any I am hoping to figure out a way to be able to easily set them at an angle when I want to - and that might be more easily done from the side - without crawling on the roof constantly (I'm too old for that now) .. but we will have to see about that dream.
Thanks again for the input. Back to my drawing board.
1 - 17 of 17 Posts
