1 - 3 of 3 Posts
Does it annoy anyone else besides me that the 12v outlets in center console are switched instead of always hot?
Anyone convert them?
Many have on the full size Promaster. It’s not difficult just cut the existing power wire and connect a new one up to a fused position on the fuse box. I have no idea what a City fuse box looks like or where it’s located but it would be the same on every vehicle. If you would rather simply run a new wire directly to the positive side of the battery and fuse it instead of going to the fuse box.
I plan on doing this so my phone charges when it's off and the front camera continues to record. Each outlet has a dedicated fuse, it should be easy enough to just run a #8 wire fused from the battery to the fuse block then inserting a male terminal into the load side of the fuse.
Sent from my LG-H918 using Tapatalk
1 - 3 of 3 Posts
