Hi - running a Thanksgiving weekend sale on the 1 kW class drop in power systems that we build.
Must be a promaster forum member.
_
This offering is for the "1 x 1 (TM) Power system.
The details are in the description, but it is a ruggedized / suitcase size power system in a case.
Power inputs / charging from:
All built in.
Power outputs for:
____
This model is particular good for applications where the van will be used in cold weather. It is one of the most robust, 1 kW class van electrical setup around for cold or hot weather use.
It will power 12 volt heaters and refrigerators under conditions where many other systems will fail. Far beyond the temperature range of a typical retail type power system / solar generator.
Regulated 12 volt output means that you don't have to worry about too high of voltage for your exhaust fan, or too low of voltage for the heater or refrigerator
Can also be used to power critical loads in a home, such as a furnace or refrigerator when the power is out.
wirlnet-inc.square.site
__
Sale runs from now until midnight Sunday night, 2021 November 28.
20% off of this line item.
Contact me via private messaging for a discount code
___
Harry N
_
- solar panels
- 120 vac
- 12 volt vehicle power input.
All built in.
Power outputs for:
- 120 vac (10 amps)
- USB
- 24 volt (unregulated)
- 12 volt regulated via the 12 volt distribution panel.
____
1x1 Drop in power system for conversion vans | WirlNet, Inc
Drop in electrical system for conversion vans- Save time on your conversion van project- System is designed to hold the batteries, inverter, solar charge controller, and battery to battery charger all inside of one off-the-shelf box- Voltage regulated outputs so that your diesel or gas heater...
___
Harry N
