Max Tire Pressure vs Load - Ram Promaster Forum
User Tag List
Thread Tools
post #1 of 8 Old 04-25-2019, 05:56 PM Thread Starter
ctex
Junior Member
ctex's Avatar
Quoted: 4 Post(s)
(Thread Starter)
Hey guys,
I got some General Grabber tires for my new 17" wheels. The max air pressure for them is 44psi. The stock tires have a max air pressure of 80psi. If you have the tires under 65psi, the light comes on that you need to put air in the tires. The max load for the stock tires is 2470 (single) and 2680 (dual). The new tires I have has a max load of 2469, but way less air pressure is required. I am going to be driving this van all over the country and just want to make sure I will be OK with what I have. Thanks for any help!
-CT
-Cory Texter
@CoryTexter
ctex is offline
Sponsored Links
Advertisement
post #2 of 8 Old 04-25-2019, 08:29 PM
phil
Senior Member
Quoted: 341 Post(s)
Get your van weighted at a Cat Scale so you can verify the front and rear axle weights.
phil is offline
post #3 of 8 Old 04-25-2019, 08:59 PM
Chance
Senior Member
Quoted: 270 Post(s)
Quote:
Originally Posted by ctex View Post
......cut..... The max load for the stock tires is 2470 (single) and 2680 (dual). The new tires I have has a max load of 2469, but way less air pressure is required. .....cut.....
Your single versus dual load ratings are likely backwards. Single load ratings per tire are higher than when used as duallies.
Chance is offline
Sponsored Links
Advertisement
post #4 of 8 Old 04-25-2019, 09:53 PM
phil
Senior Member
Quoted: 341 Post(s)
Hey guys,
I got some General Grabber tires for my new 17" wheels...cut...
-CT
Out of curiosity what is the tire's entire name and the size?
phil is offline
post #5 of 8 Old 04-29-2019, 03:04 PM
baitbegger44##
Senior Member
baitbegger44##'s Avatar
Quoted: 69 Post(s)
You can go to the ram dealer and they can do the computer thing to tell which tires are rated for your promaster.....you can then go to Amazon and buy them about 1/2 price......i talked deal and got better price @ dealer but not better than amazon....but got free rotating for life of tire with mileage warrenty and price break on tire alignment....if you buy from Amazon someone has to put them on
baitbegger44## is offline
post #6 of 8 Old 04-29-2019, 03:20 PM
afox
Senior Member
Quoted: 113 Post(s)
yeah but its a little more complicated since dealer is going to tell you which tires are rated for max load of your promaster. many of us with campervans are never going to come close to max load in our PMs. what we really need to know is what tires are rated for our loads (current and anticipated) and at what tire pressure.
afox is offline
post #7 of 8 Old 04-29-2019, 04:58 PM
GaryBIS
Senior Member
GaryBIS's Avatar
Quoted: 297 Post(s)
You might find this old post helpful:
https://www.promasterforum.com/forum...ad.php?t=47137
I was going through somewhat the same thing trying to figure out how low I could safely go on tire pressure given that my actual axle weights are much lower than what the van is designed for.
Unfortunately, the inflation pressure vs allowable tire load link I gave is not working anymore, but you should be able to find the data online. You need the equivalent chart for your tire. If you can't find it online, the manufacturer should be able to provide it.
My dealer lowered the threshold pressure for my TPMS so that it does not come on even with the lower tire pressures I run -- they did not even charge for this!
136 WB PM, high roof, 1500, gasser, 2014.
SW Montana
www.BuildAGreenRV.com
GaryBIS is offline
The Following User Says Thank You to GaryBIS For This Useful Post:
afox (04-29-2019)
post #8 of 8 Old 04-29-2019, 04:59 PM
baitbegger44##
Senior Member
Quoted: 69 Post(s)
What about the uconnect problem----- I mean opportunity
Reply
Thread Tools
Forum Jump
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
