Aftermarket Tire Air Pressures - Ram Promaster Forum
User Tag List
Thread Tools
post #1 of 5 Old 04-25-2019, 05:52 PM Thread Starter
ctex
Junior Member
ctex's Avatar
Quoted: 4 Post(s)
(Thread Starter)
Hey Guys,
I just installed 17" wheels and got General Grabber tires for my Promaster 159". The max PSI for this tire is only 44psi, where the stock Promaster Tires have a PSI of 80psi.
Stock Max Load is 2470 for single and 2680 for dual
With these new tires the max load is 2469.
Will I be ok running these new tires?
-Cory Texter
@CoryTexter
ctex is offline
Sponsored Links
Advertisement
post #2 of 5 Old 04-25-2019, 06:37 PM
MtBiker
Senior Member
MtBiker's Avatar
Quoted: 32 Post(s)
Garage
If the load range is correct than the manufacturers max PSI should be good. Do not run more than the manufacturers pressure rating when the tires are cold.
Your pressure sensors are not going to work at that range. You may want to see if you can get the dealer to adjust range on the computer.
You may get a bit of rear tire squirm when loaded and at freeway + speeds.
Nice run in Texas
2017, High Top/159 WB, 2500 gas Promaster
MtBiker is offline
post #3 of 5 Old 04-25-2019, 08:23 PM Thread Starter
ctex
Junior Member
ctex's Avatar
Quoted: 4 Post(s)
(Thread Starter)
That's what I thought and was hoping. Appreciate it. And thank you. It was a good weekend!
-Cory Texter
@CoryTexter
ctex is offline
Sponsored Links
Advertisement
post #4 of 5 Old 04-25-2019, 08:51 PM
pjoconnor2001
Junior Member
Quoted: 6 Post(s)
A dealer has the ability reprogram the sensor activation to any PSI you desire, if they are willing. Many (mine incl) will not fearing potential liability. Many with the bone jarring Vancos run reduced pressures. This does reduce the max load recommended by the manufacturer. I believe when I looked it up when deciding to run 55 psi myself, it reduced the max load from 3195 to 2270 lbs each (So, 464 lbs. under the max rear axle rating of my 118 van, not a problem for me in typical usage).
One note, if you are using a tire not designated at least “LT” the tire manufacturers advise to de-rate the published max load rating by 9%.
2017 118" WB, Gas, Deep Cherry Red Crystal Pearl (Dark Red if you're not in marketing).
pjoconnor2001 is offline
The Following User Says Thank You to pjoconnor2001 For This Useful Post:
dttocs (04-25-2019)
post #5 of 5 Old 04-29-2019, 03:41 PM
Wankel7
Senior Member
Wankel7's Avatar
Quoted: 84 Post(s)
What exact tire did you get? Size and load index?
Wankel7 is offline
Reply
Thread Tools
Forum Jump
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
