L.e.d. headlights - Ram Promaster Forum
User Tag List
Reply
Thread Tools
post #1 of 39 Old 03-28-2019, 07:11 PM Thread Starter
RoadPirate
Junior Member
RoadPirate's Avatar
Quoted: 2 Post(s)
(Thread Starter)
L.e.d. headlights
Just replaced my factory headlights a few weeks ago. They weren't burnt out, even after a year and 3 months. I tried the Sylvania ZXE Golds and they were junk. Bright, but liight was all over except the road....couldn't grt them adjusted...tried an h7 led light, but it only had 2 leds....1 top and 1 bottom...light output was ok, but not spectacular by any means. A little better beam on the road, but not great. They will probably be alright in the hi beams, which i swapped to see. The new H7s i ordered have leds on all for sides, plus a fisheye lense on the end which shoots into the nacelle where the stock bulb shoots.
RoadPirate is offline
Sponsored Links
Advertisement
post #2 of 39 Old 03-28-2019, 07:20 PM
jerothle
Member
Quoted: 11 Post(s)
What was used to hold the LED in place?
Thanks for posting.
2018 159" V6, high roof, front windows only
jerothle is online now
post #3 of 39 Old 03-28-2019, 08:18 PM
Wowbagger
Senior Member
Quoted: 47 Post(s)
I suspect you are not going to get a good pattern from that bulb. The reflectors are designed for a thin, long filament at a specific location. The bulb you show won't line up, and you are likely going to have a lot of light going up when it should be going down.
I upgraded my headlights to LEDs, but they have the chips arranged as 2 rows of LEDs, one on each side, so that it will correctly illuminate the reflectors and give me a sharp line on the low beams. I also offset the high beams so that I get a large area illuminated on the road.
A bulb like you show would be great for the fog lights.
Wowbagger is offline
Sponsored Links
Advertisement
post #4 of 39 Old 03-28-2019, 10:55 PM Thread Starter
RoadPirate
Junior Member
RoadPirate's Avatar
Quoted: 2 Post(s)
(Thread Starter)
Quote:
Thanks for posting.
just plugs in
post #5 of 39 Old 03-28-2019, 11:00 PM Thread Starter
RoadPirate
Junior Member
RoadPirate's Avatar
Quoted: 2 Post(s)
(Thread Starter)
Yeah, im seeing that...what bulbs do you use?? I I know they're size specific....just experimenting. I'd order a set of what your using, asap!!!..i use the Sylvania fog leds and love them. Like those better than a few others i tried.
post #6 of 39 Old 03-28-2019, 11:15 PM
Old Country Woodworks
Member
Quoted: 20 Post(s)
The sylvania H7 ZEVO LED works great, NOT FOG
Install with silicone
Pricy at 200 canadian but I have easily spent that on replacements.
Old Country Woodworks is offline
post #7 of 39 Old 03-29-2019, 08:03 AM
Wowbagger
Senior Member
Quoted: 47 Post(s)
post #8 of 39 Old 03-29-2019, 10:47 AM Thread Starter
RoadPirate
Junior Member
RoadPirate's Avatar
Quoted: 2 Post(s)
(Thread Starter)
Thankya very much!!! I figured i wasn't going to like the bulbs i bought, but for 20 bucks its all good. Gonna order those Supernovas today. Thanks!!!
post #9 of 39 Old 03-29-2019, 01:54 PM Thread Starter
RoadPirate
Junior Member
RoadPirate's Avatar
Quoted: 2 Post(s)
(Thread Starter)
Just swapped the hi/low beams out with each other on both sides. The low leds are dual sided which puts the leds on a left/right config in the housing which is how they are replicating the original reflector and bulb filament design for the oe halogen bulb. They dont have the output i expected, which is why i bought the 5 sided ones......more is better, right???😂🤣
The setup i have now will work until i recieve my new ones. It seems most manufacturers in 2019 have already figured out how to position the leds in the same position as a stock halogen filament, so it seems most will work, especially just using rtv red to hold it in place.
post #10 of 39 Old 05-04-2019, 10:36 AM Thread Starter
RoadPirate
Junior Member
RoadPirate's Avatar
Quoted: 2 Post(s)
(Thread Starter)
Finally installed and red RTV'd my new Aikee LEDs...definitely better than stock.
The Following User Says Thank You to RoadPirate For This Useful Post:
bahawton (05-04-2019)
Reply
Thread Tools
Forum Jump
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
