159" Otto Vahn - Ram Promaster Forum
User Tag List
Reply
Thread Tools
post #1 of 18 Old 02-14-2019, 01:29 PM Thread Starter
brrogers12
Junior Member
brrogers12's Avatar
Quoted: 2 Post(s)
(Thread Starter)
Question 159" Otto Vahn
Hi All - Just starting my conversion and thought I'd start a thread to document our build and ask questions as necessary. (I know there are MANY threads on topics similar to this but I find the search function inherently difficult and convoluted).
My first question has to do with insulation...thinking about doing the Frost King duct insulation on the floor as a vapor barrier and then doing Polyiso. Has anyone had any experience with this method either good or bad. Let me know your thoughts. It's a fairly expensive product so want to make sure I'll be getting value out of it.
Can't wait to share our build with this amazing community. Thanks in advance for your help!
brrogers12 is offline
Sponsored Links
Advertisement
post #2 of 18 Old 02-14-2019, 02:40 PM
keeponvaning
keeponvaning's Avatar
Quoted: 959 Post(s)
Polyiso is a vapor barrier
keeponvaning is online now
The Following User Says Thank You to keeponvaning For This Useful Post:
brrogers12 (02-14-2019)
post #3 of 18 Old 02-14-2019, 02:47 PM
phil
Senior Member
Quoted: 317 Post(s)
IMO, don't spend that kind for money and effort for a small gain.
Why do you need a vapor barrier?
The money for the Frost King would be better spent on a roof vent and dry heat heater, IMO
phil is online now
The Following User Says Thank You to phil For This Useful Post:
Sponsored Links
Advertisement
post #4 of 18 Old 02-14-2019, 03:56 PM Thread Starter
brrogers12
Junior Member
brrogers12's Avatar
Quoted: 2 Post(s)
(Thread Starter)
Quote:
I know this is a pretty controversial topic: to vapor barrier or not to vapor barrier - *that* is the question.
post #5 of 18 Old 02-14-2019, 04:00 PM Thread Starter
brrogers12
Junior Member
brrogers12's Avatar
Quoted: 2 Post(s)
(Thread Starter)
My other big lingering question is how everyone tackled the screw and bolt holes in the flooring to prevent moisture from coming up?
post #6 of 18 Old 02-14-2019, 04:01 PM
phil
Senior Member
Quoted: 317 Post(s)
Quote:
I think this page has a good explanation and solution, I also use heat and ventilation to control the moisture level.
https://faroutride.com/condensation-moisture-van/
phil is online now
junkycosmos (02-16-2019)
post #7 of 18 Old 02-14-2019, 04:06 PM
phil
Senior Member
Quoted: 317 Post(s)
My floor is held down with the cargo tie down bolts, so no screws or glue.
phil is online now
post #8 of 18 Old 02-14-2019, 04:07 PM
DansVansCo
Junior Member
DansVansCo's Avatar
Quoted: 0 Post(s)
New build! Have fun with it!
DansVansCo is offline
post #9 of 18 Old 02-14-2019, 06:16 PM
SteveSS
Senior Member
Quoted: 184 Post(s)
Garage
Ditto. I used all of them to secure the plywood floor and poly-iso with 8mm flathead machine screws countersunk into the plywood. Poly-iso is an effective vapour barrier all by itself. I taped the poly-iso seams with red tuck tape, which also keeps them from shifting. Stuffing foam backer rod around the edges at the walls completes the job. BTW, the plywood/poly-iso combo is also plenty strong enough to span the floor channels, so don't worry about filling them in.
SteveSS
2017 3500 159 EXT gas, silver metallic. Shiny's build thread
SteveSS is online now
The Following User Says Thank You to SteveSS For This Useful Post:
phil (02-14-2019)
post #10 of 18 Old 02-15-2019, 03:58 PM Thread Starter
brrogers12
Junior Member
brrogers12's Avatar
Quoted: 2 Post(s)
(Thread Starter)
Quote:
Did you (or Phil) have any other screw holes in the floor? My floor is covered with random screw holes throughout the cargo area. These are not the same as the bolt tie-down holes. I'm thinking of sealing the tiny holes with silicon. Thoughts?
Reply
Thread Tools
Forum Jump
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
