Battery mounted fuse block bolts? - Ram Promaster Forum
User Tag List
Reply
Thread Tools
post #1 of 44 Old 04-02-2016, 09:13 PM Thread Starter
Wowbagger
Senior Member
Quoted: 46 Post(s)
(Thread Starter)
I'm wanting to add a fuse to the high current fuse block mounted on the positive terminal of my 2016 diesel's battery. I need to find a source for the square headed studs that go through that block and allow mounting a fuse down. Does anybody know what the correct term for those is, and where to get them?
Wowbagger is offline
Sponsored Links
Advertisement
post #2 of 44 Old 04-03-2016, 03:34 AM
keeponvaning
keeponvaning's Avatar
Quoted: 988 Post(s)
If we are talking about the same thing you can just get a bolt off te shelf and accomplish what you want to do. I think I used a 5/16" SS one about an 1" long with a nut and lock washer to make the stud then I bolted one end of the fuse to the stud.
keeponvaning is online now
The Following User Says Thank You to keeponvaning For This Useful Post:
KNDLKSTMS (04-06-2017)
post #3 of 44 Old 04-03-2016, 08:37 AM Thread Starter
Wowbagger
Senior Member
Quoted: 46 Post(s)
(Thread Starter)
That's what I've done so far, but I'd rather do it right - having something that I can reliably unbolt from the top without losing the bolt would be nice.
Sponsored Links
Advertisement
post #4 of 44 Old 04-03-2016, 08:53 AM
keeponvaning
Quoted: 988 Post(s)
You use two nuts. One on the bottom and one on the top. It will never move if you use either a lock washer or lock nut. I know from past experience because I forgot the lock washer when I was doing it the first time and ended up with a weak connection and couldn't figure out why. Once I took it apart to check it I realized the problem and after putting the lock washer in it has been perfect!
ordo123 (11-28-2017)
post #5 of 44 Old 04-03-2016, 08:29 PM Thread Starter
Wowbagger
Senior Member
Quoted: 46 Post(s)
(Thread Starter)
That's what I have done so far, but I'd still rather do things the correct way.
Does anybody else know what to Google to find what I need?
post #6 of 44 Old 08-16-2017, 09:44 AM
PopeAng
Senior Member
PopeAng's Avatar
Quoted: 48 Post(s)
Quote:
KOV can you share a picture of what this looks like?
My electrician will soon be getting to connecting my battery doctor to the van battery. He wants to install a 150amp fuse at the van battery. He said he needs 2 bolts and washers, and a 150amp fuse. I am thinking he is trying to do something similar to what you did. I'm thinking I need to add lock washers and a few nuts to that shopping list...?
PopeAng is offline
post #7 of 44 Old 08-16-2017, 11:19 AM
keeponvaning
Quoted: 988 Post(s)
That is the picture it's the cable going to the black 175 amp Mega fuse. Just use a ss bolt, lock washer and nut on each end of the fuse and you're hood to go.
PopeAng (08-16-2017)
post #8 of 44 Old 08-16-2017, 11:41 AM
RDinNHandAZ
Senior Member
RDinNHandAZ's Avatar
Quoted: 1490 Post(s)
Garage
Wowbagger,
You say "That's what I have done so far, but I'd still rather do things the correct way.
Does anybody else know what to Google to find what I need?”
Strange- I thought KOV did do it right! And no, I too don’t know what the “right” thing you want is or what it is called, sorry.
RDinNHandAZ is online now
post #9 of 44 Old 08-16-2017, 11:46 AM
keeponvaning
Quoted: 988 Post(s)
Maybe a few turns with duct tape and a wire tie would be easier to remove? Personally, I think my way is better and safer, but what do I know?
post #10 of 44 Old 08-16-2017, 12:34 PM
MtBiker
Senior Member
MtBiker's Avatar
Quoted: 36 Post(s)
Garage
Did mine exactly like this.
2017, High Top/159 WB, 2500 gas Promaster
MtBiker is online now
Reply
Thread Tools
Forum Jump
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
