Device to lock rear doors open 90 degrees? - Ram Promaster Forum
User Tag List
Reply
Thread Tools
post #1 of 14 Old 04-15-2019, 03:53 PM Thread Starter
travelvanvan
Senior Member
travelvanvan's Avatar
Quoted: 88 Post(s)
Garage
(Thread Starter)
Idle thinking alert! Wondering if someone has seen or come up with a device that will lock the rear doors open 90 degrees. In other words, straight back. I can't remember exactly which van, but I thought I saw something like this from a different make (Nissan NV2500?).
I could find this useful for a number of reasons. Doors not swinging in the wind or due to a slope, etc.
If the door is fixed in this position, I could rig some steps that could fold out from the doors to help me climb up on the roof (solar panel cleaning). I warned you, this was idle thinking at play!
I recall a member having a cable-based "stop" that would prevent the doors swing *greater* than 90 degrees, but I don't think it'd prevent it swing back closed.
Ordered Feb 2018, arrived Sept 2018. 159-inch WB regular length, high top, 3.6L gas, both driver's and passenger-side sliding doors. Planning to lightly camper-ize it for spontaneous and free-spirited travel!
travelvanvan is online now
Sponsored Links
Advertisement
post #2 of 14 Old 04-15-2019, 04:07 PM
MsNomer
Senior Member
MsNomer's Avatar
Quoted: 750 Post(s)
Sprinter has a retractable bar that does that. You might borrow from their design.
www.woodworkingtraveler.wordpress.com
Website detailing my build: msnomersvan.wordpress.com
2014 White 136" HT 1500 Gas
MsNomer is offline
The Following 2 Users Say Thank You to MsNomer For This Useful Post:
bahawton (04-16-2019), travelvanvan (04-15-2019)
post #3 of 14 Old 04-15-2019, 04:48 PM
phil
Senior Member
Quoted: 314 Post(s)
I rigged something up, crude but it works.
Eye bolt thru existing holes in the upper corner of each door.
2 tubes/pipes/dowels that connects the eye bolts to the upper center latch bars.
The tubes have approx 45° cut on the ends and a hole drilled thru each end.
By inserting a retaining pin thru each hole and thru the latch bar/eye bolt it will hold the doors open.
If you reduce the opening to say 80°-85° you allow traffic behind you to see your tail lights, why? so I can can load long lengths on wood at the store and drive home. I can do 14 footer in my 1500.
phil is offline
The Following User Says Thank You to phil For This Useful Post:
Sponsored Links
Advertisement
post #4 of 14 Old 04-15-2019, 06:30 PM
mostlyHarmless
Member
mostlyHarmless's Avatar
Quoted: 6 Post(s)
Are you planning on driving with them open, for really long material (hense the 90 degree desire and no more?), or is this more for wind protection when doors are open?
this is a strength of the NV and Transit over the PM for conversion, they both have keeper arms that stop the doors at 90 (ish) then you slid a lever and can open them up all the way around to magnetic locks that hold the doors in place.
As for a mod for the PM i think the easiest, cheapest and most effect would be a bar that rest across the top of the doors, some channels that slide over the metal. Could pad the channel so it doesn't scratch the doors.
An alternative to built in steps is a collapsible ladder. this is the option i went in our bus build, really happy with the ladder (got ours at Jerrys, not sure if the link is to the same brand, but it is the same design). Upside is you can use it anywhere on any project as well:
2018 Ram Promaster 159 wb - converting to an "off grid" camper/work rig for our family of 4.
mostlyHarmless is offline
The Following User Says Thank You to mostlyHarmless For This Useful Post:
post #5 of 14 Old 04-15-2019, 06:51 PM Thread Starter
travelvanvan
Senior Member
Quoted: 88 Post(s)
Garage
(Thread Starter)
https://www.amazon.com/Bowoshen-Tele...a-666005172444
Having a ladder is indeed helpful for other things. I just wanted a quick and dirty (possibly slightly dangerous) way of getting up on the roof easily.
I've seen a video where someone simply goes up on their platform bed above the garage area, put one foot on the upper hinge of the passenger side rear door and clambers up that way. A little risky and so I thought I'd think of a similar way but with a better toe hold.
I've seen those ladders. Do you feel 10.5 ft is good enough. I've seen a 12.5 but it's bigger and harder to store. (The 10.5 can fit onto one of the rear doors and if you have windows, it doesn't even impede the view.
post #6 of 14 Old 04-15-2019, 06:52 PM Thread Starter
travelvanvan
Senior Member
Quoted: 88 Post(s)
Garage
(Thread Starter)
Nice, Phil; that will work.
post #7 of 14 Old 04-15-2019, 07:01 PM
phil
Senior Member
Quoted: 314 Post(s)
Quote:
Forgot to add,
The ends of the pipes need a slot(mine are approx 1/4") so the eye bolt/latch bar slides into, (sort of like a finger joint)
Similar to this,
http://i.imgur.com/4x0x1gC.jpg
phil is offline
post #8 of 14 Old 04-15-2019, 07:10 PM
mostlyHarmless
Member
Quoted: 6 Post(s)
the one i have is actually an 8' when extended.. if im remembering rightly. Compacts down under 30". Its been great for everything i do: project or getting up on top of the bus (now van.) The only advantage i see to going taller in relation to a van is you can have it extend up over the top (but you would want to pad the area you are leaning against *where as leaning it jsut below the roof height, you can make use of the rubber top of the ladder*), which is proper ladder safety, but i've found mine to work jsut fine.
Here is another idea for steps to attach to door or anything else, jsut set them into something stouter than the sheet metal, may have to install a 2x6 or something the set to.
https://www.grainger.com/product/3VR...s!469961822100!
travelvanvan (04-16-2019)
post #9 of 14 Old 04-15-2019, 07:13 PM
mostlyHarmless
Member
Quoted: 6 Post(s)
note on those telescoping ladders, you can extend them out to any length (full extend each rung individually), up to the maximum height. kinda nice for shorter work.
post #10 of 14 Old 04-16-2019, 12:57 AM Thread Starter
travelvanvan
Senior Member
Quoted: 88 Post(s)
Garage
(Thread Starter)
Thanks, that Grainger part could help me clamber onto the roof without using the hinge.
Reply
Thread Tools
Forum Jump
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
