Swap Fixed Slide Door Window For CRL Vented? - Ram Promaster Forum
User Tag List
Thread Tools
post #1 of 6 Old 06-11-2019, 12:35 AM Thread Starter
OSIN
Junior Member
OSIN's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Hi folks.
I'm trying to swap our fixed window on the passenger slide door for a vented option. We're getting conflicting info from both CR Lawrence Documentation and DK Hardware reps? Some say NO and others say Yes?
Has anyone swapped out the standard fixed window for a FW395R vented window from CR Lawrence.
Thanks in advance, Paul
OSIN is offline
Sponsored Links
Advertisement
post #2 of 6 Old 06-11-2019, 09:09 AM
RobPromaster
Senior Member
Quoted: 41 Post(s)
Welcome to the forum.
Have you done a youtube search about removing the side slider window?
I remember seeing a video, viewed so many before installing my CRL vented side window, could not tell you where I saw it, about removing the stock window.
Love my new window btw.
Remember guys using a hot wire to get old window out. Took a bit of effort. Probably worth it.
'18 Promaster 1500 HR gasser, bare bones, Working on it
98 Ram 3500 Cummins 12v diesel
RobPromaster is offline
The Following User Says Thank You to RobPromaster For This Useful Post:
OSIN (06-12-2019)
post #3 of 6 Old 06-11-2019, 09:59 AM
proeddie
Senior Member
Quoted: 526 Post(s)
As far as removing the stock glued on window, a local glass place removed mine with a wire, not hot, just a wire that they used to "saw" thru the adhesive. At the top corners, there are two plastic clips that velcro to the window, and two velcro tabs at the bottom corners that pop out when you remove the factory window. The black strip you see is the remaining adhesive which is cleaned before the new window is glued in.
I had mine removed to replace it with a CRL glued in window (to match the tinting of the other CRLs I installed).
(2014 glued in factory slider door window available for sale if anyone is interested ! )
I believe that the issue with replacing that window with a CRL clamp on version is that the factory cut hole is not the same as the one needed for the clamp ring of the CRL. Question is: is the hole bigger or smaller than the hole required by the clamp on CRL vented version?
Working on the van, and my website about it! Please visit www.empowersites.com/edsvan or here on the forum
proeddie is offline
The Following User Says Thank You to proeddie For This Useful Post:
OSIN (06-12-2019)
Sponsored Links
Advertisement
post #4 of 6 Old 06-11-2019, 11:36 AM
RobPromaster
Senior Member
Quoted: 41 Post(s)
There You Go
Quote:
YMMV
I made a template of the new window using the trim ring. Used a Sharpie to trace it out. The lines matched up pretty well with the inner. But I had no old window. Cut out the center brace with a cutoff saw. Then went at it with a reciprocal saw. Finished up with a 4" grinder and painted the edge.
Window fits well.
post #5 of 6 Old 06-11-2019, 11:56 AM
proeddie
Senior Member
Quoted: 526 Post(s)
RP,
The original post concerns a slider that already has a glued in window, so there is a hole already there... depending on how the factory cut hole matches up with the CRL-required clamp ring hole, there may or may not be an issue.
Adding a new window to a blank piece of metal is a different story!
proeddie is offline
post #6 of 6 Old 06-12-2019, 02:24 AM Thread Starter
OSIN
Junior Member
OSIN's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Thanks, I'll pass this tip on to the installer.
Paul
OSIN is offline
Reply
Thread Tools
Forum Jump
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
