Tire Pressure Monitoring System (TPMS) Light - Page 5 - Ram Promaster Forum
post #41 of 49 Old 09-18-2018, 08:57 PM
airstream66
Quoted: 3 Post(s)
Light instantly went off
I just went and added air to the spare for the first time and right away I could see that it was at most about 65 or maybe a tad under that and the sticker calls for 80 in the spare. I probably only added enough to get it up to 73 or 75 I'm guessing. I did check the other tires and they were all close to spec. So I have to assume that the spare was what was causing my light to be on. As soon as I started the van the light did not come on. It did not require any time or driving.
airstream66 is offline
post #42 of 49 Old 02-14-2019, 05:38 PM
[email protected]
mcneill78@windstream.net's Avatar
Quoted: 28 Post(s)
Smile
Had a crack in the last baffle on the exhaust and had it in to be fixed under warranty. Also asked to have TPMS adjusted to 55 psi all round. Went to pick up and service manager told me could not reset, it comes from the factory that way. REquested he have his master tech double check since this appears to be something many forum members have had adjusted. 30 minutes later TPMS was adjusted to 55 all round and the service manager asked and was granted a tour of the van.
[email protected] is offline
post #43 of 49 Old 02-14-2019, 06:04 PM
Old Country Woodworks
Quoted: 20 Post(s)
I have found that the light will come on on a very hot day or a very cold day. There seems to be a 5-10 pound window +-. It also takes maybe 100 KM for it to recalibrate itself. I switch to winter tires and rims in the winter so my TPMS only works in the spring summer fall.
I run 65 pounds year round.
If the spare has a unit in it is an interesting question.
Old Country Woodworks is offline
post #44 of 49 Old 02-14-2019, 06:15 PM
phil
Quoted: 350 Post(s)
Originally Posted by Old Country Woodworks View Post
...cut...If the spare has a unit in it is an interesting question.
Nobody has reported that the factory spare doesn't have one, that said, if I understand these sensor correctly they activate when a rotational force is applied, so only 4 are active.
phil is online now
The Following User Says Thank You to phil For This Useful Post:
Old Country Woodworks (02-14-2019)
post #45 of 49 Old 02-14-2019, 06:25 PM
SteveSS
Quoted: 194 Post(s)
From the owner's manual
"The spare tire has a tire pressure monitoring sensor, but it is not monitored until it is mounted in place of any of the existing four road tires."
SteveSS
2017 3500 159 EXT gas, silver metallic. Shiny's build thread
SteveSS is offline
The Following 2 Users Say Thank You to SteveSS For This Useful Post:
bahawton (05-21-2019), [email protected] (02-14-2019)
post #46 of 49 Old 05-22-2019, 09:07 PM
GuyT
GuyT's Avatar
Quoted: 150 Post(s)
Got tired of that tire pressure warning, asked the dealer to set it to the lowest pressure threshold available, since it can't be disabled. No more warnings.
GuyT is offline
The Following User Says Thank You to GuyT For This Useful Post:
MXHauler (05-23-2019)
post #47 of 49 Old 05-23-2019, 10:55 AM
bahawton
Quoted: 10 Post(s)
This might be another option for people with dealers that are unwilling to change TPMS settings. I already have the OBDII adapter so it looks like it would only cost me $50 for the app plus it would allow me to change other settings (once my new van arrives).
https://play.google.com/store/apps/d...faOBD&hl=en_US
http://www.obdlink.com/mxp/
bahawton is offline
The Following User Says Thank You to bahawton For This Useful Post:
GuyT (05-24-2019)
post #48 of 49 Old 05-23-2019, 11:18 AM
tbuyan
Quoted: 12 Post(s)
GuyT, did the dealer in Hood River adjust the TPMS for you?
tbuyan is online now
post #49 of 49 Old 05-24-2019, 12:00 PM
GuyT
GuyT's Avatar
Quoted: 150 Post(s)
No, I had it done in Montreal, Boulevard Dodge Chrysler.
GuyT is offline
tbuyan (05-25-2019)
