Completed our PM conversion a few months ago. We've had a great time camping and visiting friends and family but are now ready to travel outside the U.S. and will be selling our awesome PM conversion.
Available November 2018. Able to pick up from airport in New Orleans or Baton Rouge. Continental U.S. delivery options negotiable.
Vehicle: 2017 159" RAM ProMaster 2500 (High-Roof)
Engine: V-6, 3.6 liter
Transmission: Automatic (FWD)
Mileage: Estimated 28K miles by November 2018.
Warranty: 3-Year / 36,000 mile Bumper to Bumper Coverage, 100K mile powertrain warranty (both are transferable to buyer)
Extended Protection Plan: Free Roadside Assistance/Key Replacement/Tire Repair (transferable to buyer)
AUDIO AND VISUAL
Pioneer AVH-2300NEX Multimedia DVD Receiver
• 7" WVGA Display
• Apple CarPlay/Android Auto
• Built-in Bluetooth
• SiriusXM-Ready/AppRadio Mode +
ROSTRA 160-degree reverse camera
CAMP BUILD FEATURES
MaxxAir 7000K Deluxe Fan w/ Remote
• Powerful 10-speed intake and exhaust fan
• Thermostat to control room temperature
• Air intake and/or exhaust functions
Thermal Blackout Curtains in Cargo/Cabin Partition
INSULATION AND SOUND DEADENING
Floor is two layers of ½" (1" total) polyiso R-6 insulation covered by ¾" marine birch plywood planks and LifeProof luxury vinyl flooring (7mm insulated and sound deadening 100% waterproof planks with rigid PVC core and durable wear layer).
Walls are insulated with polyiso foam board in various thickness depending on wall voids (2" in deepest area) cut to fit and sealed with Great Stuff spray foam. Ceiling is insulated with 1" - 1.5" polyiso foam board sealed with Great Stuff spray foam. Rear door and cargo wall voids and ribs insulated with 3M Thinsulate for additional insulation and sound deadening.
NOICO 80 mil. Sound deadening on cargo van walls, ceiling and wheel wells.
CABINETRY AND WOODWORK
All cabinetry, seating, bedframe and shelving constructed by professional carpenter and cabinetmaker generally using exterior grade poplar. Two coats of ZERO VOC/Low Odor KILZ Premium primer and 2x-4x coats of BEHR Premium Plus Ultra Maui Mist paint and primer with additional durability and easy-to-clean finish.
Hinges for overhead storage are 22.5/18.5 cabinet door pneumatic gas struts. Cabinets and drawers include SeaDog marine grade push-button latches.
Overhead cabinets/hinged toilet seat/propane shelf/etc. protected by heavy duty removable industrial matting.
Ceiling cedar panels coated with low VOC water-based polycrylic
UPHOLSTERY
Cargo area seat cushions are charcoal blue button-tufted cushions made in Indian (22" sq. x 3.5")
POWER SYSTEM
Three charge sources: 45A Shore Power (w/ IQ4 smart charger), Solar and Alternator
Solar: 360W (2x 180W Grape Solar High Efficiency Monocrystalline PV Panels)
Solar Charge Controller: Victron SmartSolar MPPT 100/50 Solar Charge Controller 100V 50A w/ Bluetooth monitoring
Battery Monitor: Victron BMV-712 Battery Monitor w/ Bluetooth monitoring (able to monitor from iPhone/iPad/etc.)
Battery: XTR8D-350 12Volts 350AH Deep Cycle, XTREME AGM Battery (Deepest discharge at 91%)
Inverter: KRIËGER 1500 Watt 12V Power Inverter Dual 110V AC outlets/USB outlet
Eight USB outlet inputs
Two dual AC/USB Outlets
One 12v plug outlet
BED AREA
5-Inch Gel Memory Foam Mattress (Dual-Layered - CertiPUR-US Certified) (Full)
Stained and four-coat epoxy slide-out table
Four vertical clothes drawers
TOILET
Camco Premium Portable Travel Toilet With Three Directional Flush and Swivel Dumping Elbow (5.3 gallon)
SECURITY
Hidden RFID (card-controlled access) storage compartment for safe storage of laptops, passports, etc.
Kidde Battery Operated Carbon Monoxide Alarm w/ Digital Display
MTI Industries Safe Alert 40 Series Professional Propane/LP Gas Alarm
KITCHEN COMPONENTS
Three- (3x-) bottle stained cypress wine rack
Dometic CFX 50W (12v/120V) Refrigerator
• Refrigerates or freezes to -7F.
• Reinforced corners and a robust closing mechanism
• Control and monitor the cooling temperature in the compartment via WiFi app
• Energy-efficient LED interior light / Input voltage (Alternate current) - 100-240 Volt
• USB port for charging small electronic devices
• 3-stage battery protection
• 2 Year Warranty
Cinnamon stained cypress countertops w/ four coats of bar-top epoxy
Four (4x) warm overhead Acegloo recessed lighting above cooking area
Heavy-duty two burner recessed propane stove w/ vented propane tank storage subcabinet
600W Westinghouse rotary microwave w/ speed control and weight defrost
Single-handle chrome kitchen sink pull-down faucet with 360-degree rotatable silver deck mount
Kamenstein ratchet-system wall mounted hidden paper towel dispenser (allows paper towels to be dispensed without automatically rolling down while driving)
Subcabinet stainless steel trashcan with foot pedal and hinged lid
Recessed stainless steel sink w/ recessed cypress sink cover
Hinged stained cypress bar top for additional countertop space
Velcro Insect Screen w/ magnetic entrance enclosures for easy ingress and regress
Double-sliding tiered drawer
LIGHTING
10x warm recessed Acegloo LEDs dimmable from switch in kitchen w/ dual zone control (i.e. kitchen and sleeping area LEDs can be controlled together or separately)
4x warm recessed Acegloo LEDS (dimmable) over the kitchen cooking area
2x warm recessed Acegloo LEDS (dimmable) in rear cargo area for easy views of the bike storage area and electronics compartment at nighttime
WATER SYSTEM
Three (3x) Reliance 7 gal. BPA free water tanks (clean water/grey water/storage water)
SHURFLO 4008-101-E65 3.0 Revolution Water Pump w/ sound reduction
SHURFLO 182-200 Pre-Pressurized Accumulator Tank (Reduces pump cycling, smoothes water faucet pulses, pre-pressurized to 30 Psi)
SHURFLO (255-313) 1/2" Twist-On Pipe Strainer
REAR CARGO
Pullout bike rack for two bikes w/ two fork mount bike locks
Pullout storage compartment
Dual unit shelves
2x dimmable overhead LED lighting
ROOF CARGO
Full overhead cargo carrier rack
Brand new rooftop wind deflector included
EXTRAS
Handheld Vacuum 4KPA Hand Cordless Cleaner w/ 2200mAh Lithium Battery and five cleaning attachments
Wicker storage containers for overhead compartments and kitchen cabinets
25-foot coil hose and compressor-able (bike pump or car compressor)
7-gallon ABS shower
Electrical diagram and layout schematics available
Custom reflectix cabin window covers (never used)
PRICE: $59,000
AUDIO AND VISUAL
• 7" WVGA Display
CAMP BUILD FEATURES
UPHOLSTERY
POWER SYSTEM
One 12v plug outlet
BED AREA
TOILET
SECURITY
KITCHEN COMPONENTS
• 2 Year Warranty
LIGHTING
WATER SYSTEM
REAR CARGO
Dual unit shelves
ROOF CARGO
EXTRAS
7-gallon ABS shower
PRICE: $59,000
