Driver side door wiring diagram - Ram Promaster Forum
User Tag List
Thread Tools
post #1 of 10 Old 05-14-2019, 12:49 AM Thread Starter
Uvan
Junior Member
Uvan's Avatar
Quoted: 5 Post(s)
(Thread Starter)
I finally figure out why I'm get ambient temperature sensor error. It wasn't the sensor(I replaced it with new sensor) but somewheres in the door harness have a short. The temperature is correct when the door closed but half way through opening the door, the temp in the dash will drop out on the dash display.
Does anyone have the driver side wire diagram?
Uvan is offline
Sponsored Links
Advertisement
post #2 of 10 Old 05-14-2019, 10:08 AM
GuyT
GuyT's Avatar
Quoted: 150 Post(s)
It seams that the PM engineers have a problem coming up with wiring that can survive door motion. I had to change the wires at the backdoor hinges, for the license plate bulbs and the door lock. I didn't need the wire diagram, just replaced the faulty section, making sure I was matching both ends wire color.
The hard part in your case is accessing the wires, please keep us posted on how you did it, preferably with photos. I have a feeling I will soon have to redo the temperature sensor wiring in the driver door hinge.
GuyT is online now
post #3 of 10 Old 05-14-2019, 10:21 AM
SteveSS
Senior Member
Quoted: 189 Post(s)
Garage
SteveSS is online now
The Following User Says Thank You to SteveSS For This Useful Post:
GuyT (05-14-2019)
Sponsored Links
Advertisement
post #4 of 10 Old 05-14-2019, 11:48 AM
phil
Senior Member
Quoted: 341 Post(s)
Here is the Ducato info, I have not verified the info but I bet it's the same.
https://www.promasterforum.com/forum...79&postcount=1
pg 111 is the sensor info
pg 101 is where the connector is located
phil is online now
The Following User Says Thank You to phil For This Useful Post:
Uvan (05-14-2019)
post #5 of 10 Old 05-14-2019, 11:55 AM Thread Starter
Uvan
Junior Member
Uvan's Avatar
Quoted: 5 Post(s)
(Thread Starter)
Thanks everyone, i will update everyone on it.
Uvan is offline
post #6 of 10 Old 05-14-2019, 01:32 PM
GuyT
GuyT's Avatar
Quoted: 150 Post(s)
Uvan, I don't think you have to remove anything but the rubber accordion protector,the broken wires are more than likely in that area. I can already see wear on mine:
GuyT is online now
post #7 of 10 Old 05-14-2019, 04:38 PM Thread Starter
Uvan
Junior Member
Uvan's Avatar
Quoted: 5 Post(s)
(Thread Starter)
Im hoping I can get to those plug shown on the diagram so i can rewire the AAT sensor to somewhere else. Does anyone know if the connector in the engine bay, inside the dash or somewhere else? can't tell based on that diagram. thanks
Uvan is offline
post #8 of 10 Old 05-14-2019, 05:19 PM
phil
Senior Member
Quoted: 341 Post(s)
I'm guessing it's just above the strut mount behind fuse panel.
Disassembly starts on pg 3
pg 16 show the top of the driver's strut.
https://redirect.viglink.com/?format...41050093205182
phil is online now
Uvan (05-14-2019)
post #9 of 10 Old 05-14-2019, 08:28 PM
GuyT
GuyT's Avatar
Quoted: 150 Post(s)
A wild guess too: the wrapped wires on the gray connector on page 5 looks about the same size as the one that goes into the driver's door.
GuyT is online now
post #10 of 10 Old 05-15-2019, 02:50 AM Thread Starter
Uvan
Junior Member
Uvan's Avatar
Quoted: 5 Post(s)
(Thread Starter)
Quote:
You are right, I took the door panel off today and try to isolate where the wire issue. I bent/pull the wire loom and isolated at the rubber accordion like what you said. Its kind of hard to open up the wire loom so I'm going to try splice the connection from the connector inside the dash/firewall. After I put the door panel back, the AAT wire seems to be working better with no issue when opening the door. But I think this is just temporary.
I open up the driver side dash area as instructed above this morning. Saw the connector as shown in the diagram but there is no way I can do or see anything with the tiny amount of space. So if I really want to fix it, the "easiest" way is probably unplugging it from the door side. There is some sort of crash sensor in the middle of the door and the door harness is plug into it too. I'm scare i might F something up when i unplug it.
"there is no point in being embarrassed of all the stupid **** i done and will continue to do"
Uvan is offline
Reply
Thread Tools
Forum Jump
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
