Troubleshooting Power Window - Ram Promaster Forum
User Tag List
Thread Tools
post #1 of 3 Old 05-12-2019, 04:52 PM Thread Starter
ramuser
Junior Member
Quoted: 0 Post(s)
(Thread Starter)
Hi All
The power window on the driver side of my 2014 Promaster 2500 is not working. Here are the symptoms:
- When activating the passenger side window, there is a relay click noise (from behind the fuse panel) at the beginning, and another one at the end of the glass trip. That seems fine.
- When activating the driver side window switch, there is one relay click (on) and another one immediately after (off) (even if the switch is still pushed).
- I removed the plastic panels on the door to access the plug that feeds the window motor (http://www.rambodybuilder.com/2014/v...S/37/D3040.pdf), unplugged it and connected a Voltmeter. With the motor unplugged, every time I click the switch I see the needle move for a second (towards+12 or -12) before going back to 0 by itself.
- I believe this tells me the motor assembly itself is fine, but I can't locate the relay, or any info on how to troubleshoot the circuit upwards. The fuses F47 and F48 are ok.
Any suggestions on how to continue this troubleshooting would be much appreciated.
Cheers
D
ramuser is offline
Sponsored Links
Advertisement
post #2 of 3 Old 05-16-2019, 08:47 AM
angrymountainbiker
Junior Member
angrymountainbiker's Avatar
Quoted: 2 Post(s)
Garage
Any progress on this? I started a thread about my passenger window stuttering as it's raised. I haven't started troubleshooting yet but in my case will probably start by replacing both window switches. Passenger switch is completely missing in mine actually.
2018 Promaster 1500 136" HR
angrymountainbiker is offline
post #3 of 3 Old 05-16-2019, 10:25 AM Thread Starter
ramuser
Junior Member
Quoted: 0 Post(s)
(Thread Starter)
Quote:
It was the contacts! They were dirty!
I took the switch apart until I got to the circuit board, and cleaned it. There was some rust accumulated. Maybe at one time someone left the window open while it rained.
ramuser is offline
The Following User Says Thank You to ramuser For This Useful Post:
angrymountainbiker (05-17-2019)
Reply
Thread Tools
Forum Jump
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
