Air Conditioning not working after winter - 2500 2018 - Ram Promaster Forum
User Tag List
Reply
Thread Tools
post #1 of 12 Old 04-15-2019, 12:01 AM Thread Starter
Carrot Eater
Member
Quoted: 6 Post(s)
(Thread Starter)
I got my 2018 promaster 9/2018 and the AC worked. We didn't use the air conditioning much after 10/2018. Last week I tried using it and nothing. Anything I can check before I have to take it to the dealer?
2018 High Roof 159" Cargo Van, gas
Carrot Eater is offline
Sponsored Links
Advertisement
post #2 of 12 Old 04-15-2019, 01:19 AM
travelvanvan
Senior Member
travelvanvan's Avatar
Quoted: 120 Post(s)
Garage
Quote:
Don't scare me like that! :-)
I picked up my PM in Sept 2018 too. And I didn't even use it once after the initial test at the dealer.
It could be that the refrigerant leaked out. Or in the case of my dad's Lexus, a relay failed; the one that engaged the clutch on the A/C compressor.
Let us know what happened.
Ordered Feb 2018, arrived Sept 2018. 159-inch WB regular length, high top, 3.6L gas, both driver's and passenger-side sliding doors. Planning to lightly camper-ize it for spontaneous and free-spirited travel!
travelvanvan is online now
post #3 of 12 Old 04-15-2019, 08:12 AM
JohnnyRambles
Senior Member
Quoted: 52 Post(s)
Is the fan not working? Or is it just not blowing cold air? If the fan is working try cycling between heat and AC multiple times by turning the red/blue knob back and forth repeatedly. The Promasters are known for having an issue with the dampers sticking and it's happened several times on my van.
2015 159" Gas Promaster (RV Build in Progress)
JohnnyRambles is offline
Sponsored Links
Advertisement
post #4 of 12 Old 04-15-2019, 10:02 AM Thread Starter
Carrot Eater
Member
Quoted: 6 Post(s)
(Thread Starter)
Quote:
The fan works but the outside temp was as cool as it gets. I'll try cycling the hot/cold. I pushed the AC button on it, turning it on & off. The green LED indicator cycles on/off with each press of the button.
post #5 of 12 Old 04-15-2019, 11:03 AM
HarryN
Member
HarryN's Avatar
Quoted: 18 Post(s)
Garage
Usually you have to use an a/c at least some regularly - even in the winter - or the seals dry out and leak.
It might also be that it simply isn't warm enough yet for the A/C to allow it to turn on.
Those are speculation / guesses in case you cannot tell.
Some experience with auxiliary power
HarryN is offline
post #6 of 12 Old 04-15-2019, 11:31 AM
KilWerBzz
Senior Member
KilWerBzz's Avatar
Quoted: 194 Post(s)
At operating temp and normal idle turn the a/c on can you hear the compressor start and or does your rpm edge up if so it is most likely your blend door. If you can safely touch the a/c lines in the engine compartment one should be cold the other hot when the a/c is running or use a laser to check.
2014 Ram Promaster 2500 HR 159" Diesel
Bow to RA and offer him Cadmium Telluride and he shall reward you.
KilWerBzz is offline
post #7 of 12 Old 04-15-2019, 02:39 PM
KilWerBzz
Senior Member
KilWerBzz's Avatar
Quoted: 194 Post(s)
Quote:
Any time you turn the defrost on the a/c will run this is to dehumidify the air and speed up the defogging, but it only helps if the blend door is working.
post #8 of 12 Old 04-15-2019, 03:14 PM
travelvanvan
Senior Member
Quoted: 120 Post(s)
Garage
Understood and usually I'm good about it with our vehicles that are regularly driven. But my PM is (will be) used like an RV, in winters it just sits. I do charge the battery periodically. And I do remember starting the engine until it warmed once during the winter. Because I claim to know about this issue) I likely did turn on the AC during that time. But I can't fully remember.
post #9 of 12 Old 04-29-2019, 02:51 PM
ShaunB
Senior Member
ShaunB's Avatar
Quoted: 78 Post(s)
Garage
My AC is not working (2016 Diesel with 70,000km). I just learned from my dealer that the clutch in the compressor has a short and needs to be replaced. The part is over $1300 and labour etc is another $500+. Total bill of $2100 CDN incl. tax. I tried to source it aftermarket and there aren't any available. I'm frustrated that a vehicle just out of warranty (3 yr 60k in Canada) needs a new compressor. I just replaced the radiator a month ago!
Just venting.
Shaun
Sherpa is a 2016 3500 Ext. Diesel, Black - Our off grid cycling adventure vehicle. Also my Daily Driver. Follow my build and our adventures on https://www.instagram.com/sherpathevan/
ShaunB is offline
post #10 of 12 Old 04-29-2019, 04:10 PM
MtBiker
Senior Member
MtBiker's Avatar
Quoted: 36 Post(s)
Garage
Quote:
Just venting.
Shaun
Find an air conditioner repair shop. You should be able to get just the clutch.
2017, High Top/159 WB, 2500 gas Promaster
MtBiker is offline
Reply
Thread Tools
Forum Jump
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
