Key, switch, whole lock kit issue - Page 2 - Ram Promaster Forum
post #11 of 14 Old 03-24-2019, 01:19 PM
Pnwskier
Pnwskier's Avatar
Quoted: 5 Post(s)
This happened with my Subaru. I had to repark multiple times in order to remove the key from the ignition. I took it back to the dealership and it didn’t take long to fix. A part that tells the ignition computer to work was broken. I’ll look it up and tell you more when I get home.
Pnwskier is offline
post #12 of 14 Old 03-24-2019, 01:45 PM
mammothrunner
Quoted: 12 Post(s)
Yes, when I turn the key off sometimes I have to go back and forth on/off To get the key out. Think I’m going down the same path.
mammothrunner is offline
post #13 of 14 Old 03-24-2019, 06:24 PM
Pnwskier
Pnwskier's Avatar
Quoted: 5 Post(s)
So I looked up my records regarding this. It sounds like it was because the “cvt shifter assembly internal electrical components were not functioning properly causing the ignition key to stick in the ignition switch. The shifter select lever assembly is replaced with updated part.”
I hope this helps.
Pnwskier is offline
post #14 of 14 Old 03-24-2019, 07:37 PM
Quoted: 1512 Post(s)
Well we don't have a CVT so it has nothing to do with our vans I believe.
2015 136" HT Diesel 1500 Sandstone Pearl Metallic
Campervan build see:https://www.promasterforum.com/forum...ad.php?t=37177
You can browse my build pictures at http://tinypic.com/RDsPictures
Conversion Costs see: https://www.promasterforum.com/forum...ad.php?t=85761
$500 solar and $700 complete Electrical: https://www.promasterforum.com/forum...ad.php?t=71562
If you must make a mistake, make a new one each time.
