I'm currently having a PM 2500 HT 159" (not extended) Cargo Van (no windows) converted to a camper/rv at Morehead Design in Mills River NC. The finished van will be used to travel North America for the next couple of years, with an extended (6 months) trip to Alaska in 2015.
Because I have a real desire to avod crowded (expensive) RV parks I'm attempting to create a van that allows for extended "boondocking" and maximize the use of small campsites (no hookups) to make extended travel more cost effective. I will also be doing a good deal of my traveling solo - so I've opted for a foldaway bunk bed setup which gives me more room, but has a second bed when I have a fellow traveler. Other major differences from a more mainstream RV - no propane, no a/c, not fancy (just fictional), Webasto DualTop air/water heater, solar panels and battery bank to allow cooking with a portable induction cooktop.
The starting point:
Over the next few days I will attempt to post some "in progress" pictures, more information about some of the components, and some explanation of how/why the "Backroader" is what it is.
Yes! Looking forward to this as well. This is my plan in a couple years, so I am in research mode. I am always curious and open to see ideas from others.
Curious to see how you handle:
solar/batts etc. I am liking the products from GoalZero so far. Pricey, but modular
insulation for heat and cold and sound
toilet...tank, or not to tank?
no propane means no hassle making a sep gas box
lighting...LEDs seem to be ideal
Since you will be cooking inside a bit, does that make you steer away from cloth and carpet? odors etc?
Note - it's not your eyesight, picture is suffering the effects of a fisheye lens.
Three 100 watt solar panels, two MaxAir fans, a cellphone antenna, and a Fiamma awning - all mounted to the.new ProMaster roof rack by Fiamma. The small black box is a "combiner box" that carries the wiring to the van's interior.
I choose the MaxAir fan over the more widely used Fantastic fan because it can operate even when it's raining and also when the van is moving. Using the roof rack made for fewer holes in the roof. Obviously I won't be carrying any extra stuff up top. I do plan on carrying a small telescoping ladder so I can clean and maintain the solar panels and fan covers..
Yesterday, I noticed the three nobs on each side of the Promaster van for roof rack and wonder how they work as attachment points: "The roof can carry 400 pounds, and has three roof-rail mounts on each side with tapping plates to assist mounting roof racks." Did you use these with your Fiamma rack? I am not sure what "tapping plates" means---did you use these?
Thanks,
Doc
Thanks,
Doc
Doc -Short answer is I don't really know the specifics of the roof rack. The reason, this is NOT A DIY build and although I spent a lot of time researching the various components and what I needed for my specific adventure, I'm leaving the execution to Robert at Morehead Design. He did tell me it was a new rack designed specifically for the ProMaster (and mine was the first to use it in the US) so I assume it uses both the rail mounts and plates. I will check and let you know the next time I see it in person.
Further background: Back in my younger days I would have eagerly taken on the challenge of a DIY build, but at 70 and having just returned from 15 years abroad (last five in Panama) I would rather get on the road ASAP and enjoy the adventure. So . . . I found someone I trusted to take my input and get it done.
Thanks Steve--My van is more in the minimilist mode--had a bed built in the back and all camping gear fits underneath. This worked well on first camping trip to Big Bend, but want to add ventilation, awning, and have it insulated and paneled. It has been a bit frustrating researching how best do do all this from various venders. No one wants to put ventilation and fan on the ribbed roof; figuring out the extra battery to run the fan etc; and determining which awning to get and how to best attach it. We do back country camping, usually not in camp grounds. I did trade out the tires for Michelin all terrain which has been great. Hope to get the rest done soon.
Happy trails,
Doc
So what's your interior layout going to look like?
I've been thinking about doing something down the road in a couple years and I'm like you; pretty much by myself. It occurred to me that most of the conversions out there don't really suit my needs. I don't need two twin beds that take up a big chuck of the real estate; really just one comfortably wide twin. That means my couch/bed could be across from the counter space. Morehead has a design like that in their archives where the bed slides out all the way to the counter. Also means that that I could have a bigger shower and toilet. I'd want it at the back. Morehead's design for that is called the MDLWeekender, although I don't see an actual build for this design. The design picture is one of several at the bottom of this page:
Finally, I think I'd have room for a chest of drawers and a flat screen up front on the driver side. The TV would pull out and could be swiveled to the back or front. If I do that, I'd want a couch that has an adjustable backrest that folds up in order to watch tv. I'd mount the fridge at the rear of the counter, with the microwave mounted high next to it. I also was thinking about a table for the couch. I saw this design that would be a clever way to make a table for the couch pull out from the under counter space. I've never seen that done with an RV but I think it'd work:
Here is a early layout. We've changed a couple of things, nothing major. Front, drivers side, is the galley, then storage (with a pullout desk/table) with a cassette toilet in the back corner. On the passenger side just inside the sliding door is a small storage unit (not shown in the drawing) with a table that drops down for outside use, then the bunks (upper flods up when I'm traveling alone), a then another starage area.
Doc - The fan install looked pretty straightforward. Take a look at this thread - http://www.promasterforum.com/forum/showthread.php?t=15729 Sounds like my electrical might be more than you want/need but I will post some reports when I'm on the road on how my system functions.
John - No a/c , couldn't find a workable solution that would run on my battery bank and I didnt want to be tied to shore power. I'm hoping the ability to move to cooler weather when necessary will keep things bearable. For heat I'm using the Webasto DualTop which also provides my hot water.
Steve: I really like your design. It's very close to what I would like to do. It doesn't have a shower, although I've gone back and forth about that. I'd flip the galley and the storage area, but that's my personal preference, of course. Great idea for the pull out table. Your's is the first time I've seen it put in use and I think it's a really great idea. I'll be really interested in seeing pictures when you get it done! Please include pictures with the couch down, I'll be interested in seeing how much space that allows you, and also how wide the bed is. What does the DualTop run off of? I thought they were diesel? I'm assuming your Promaster is gas unless it's a mythical diesel Does that mean you'll have to carry a separate diesel tank? Where are you mounting the DualTop? I'll be really interested in seeing pictures of that too and also hearing about how well that works in keeping your Promaster warm. I'm also interested in hearing about whether you're installing any windows, but obviously your pictures will show that.
What does the DualTop run off of? I thought they were diesel? I'm assuming your Promaster is gas unless it's a mythical diesel Does that mean you'll have to carry a separate diesel tank? Where are you mounting the DualTop? .
Yup, the DualTop is diesel. A 3 gallon tank is mounted under the van and feeds the heater which is inside just in front of the wheelwell on the drivers side. Everyone I've talked to says this thing sips fuel and will have no problem keeping the space warm, with the bonus of providing hot water.
The first thing done to the inside: Thomas climbed into his suit and then sprayed LizardSkin ceramic insulation on the walls, ceiling and floor. The good thing about this stuff is that it's sprayed into places you can't get to with many of the other insulation products. It is an excellent condensation barrier and also gets rid of the "tin can" sound. Later in the build batt insulation was added wherever possible.
The cassette tolet is on the left. The grey box on the right is a 12v freezer (galley has a fridge). Above the freezer will be storage racks that I will wait to install until I get a better handle on what "stuff" I end up carrying.
On the far left (rear) you can see the corner of the cassette tolet, then storage (closet and pantry), under the two large doors are two drawers and a table top that slides out (bed/bench is opposite for seating), on the floor are the Webasto heater and the water tank, on the far right you can see the corner on the sink in the galley area.
That opening you see on the bottom right is where the 12v fridge will go.
Making progress - Robert at Morehead Design said they will finish the trim and cosmetic work this week and then start testing the electrical, water and heating systems. With a little luck I will leave on a shakedown trip in a couple of weeks. Excited to see how all the ideas and planning come together!
Cellphone booster, fuel gauge (diesel for heater) solar monitor, inverter/charge controller, the Webasto control, and misc switches. Think the super duper flux capacitor is tucked in back somewhere.
Looking good. Be sure and upload completed pictures of the the whole rig. I too am interested in seeing how it looks. Be sure to include pictures of the couch up and made into a bed and also with the table top pulled out.
Lot of pics coming in a couple of weeks. I'm impressed with Robert's design and build quality but his photography skills - not so much. Will take (and post) some of my own shortly, I hope.
This looks amazing Steve. I've been planning my layout for a few months now and it is always great to see new ideas. What model fridge and freezer did you end up with? Also which model solar panel? Did they do all the power calculations for the setup you have?
Both the fridge and freezer (separate units) are from Norcold. http://www.thetford.com/HOME/PRODUCTS/NorcoldIncRefrigerators/tabid/195/Default.aspx Don't have the model numbers available here at the house (one of the disadvantages of the build taking place 300 miles away) when I take delivery (in a couple of weeks) I can certainly let you know. I elected to have them delete the tiny freezer in the fridge - to me it was next to useless. Both are 110/12v only - no propane aboard.
Power calculations - not really, I read a lot, talked to folks actually out in the real world and feel comfortable the my electrical setup will handle my lifestyle. I do have room for additional solar and batteries should that become necessary. I'm using the GS100 (3) from AMSolar. If you need info for sizing a system they have some excellent information online - http://www.amsolar.com/home/amr/page_165
Your build is coming along nicely Steve.
Like others, i look forward to seeing the images you post. Especially interested in how Robert pulled of the slide-out table/chair concept you desired.
Hard to tell (before I hit the road) whether this is genius or just a dumb idea. Didn't want to waste the space so decided we would give this drop down table a try. Think it may work nicely for outdoor cooking with the portable induction cooktop, and hey, if I ever need to iron my tux I'm all set.
Steve i've seen similar installs of drop down tables and i think you will get good use of it.
You might already have this next idea in the pipeline?? Do a google search for "retractable screen door". You can mount it on the side of that cabinet and then it will pull out from the case (ours was about 3" square?) across the door opening and keep the bugs out.
we got ours from our local Home Depot and cut it to size (it's meant to do this...and they should have a handful of sizes to get you close to what you need and then trim to size from there.)
You might already have this next idea in the pipeline?? Do a google search for "retractable screen door". You can mount it on the side of that cabinet and then it will pull out from the case (ours was about 3" square?) across the door opening and keep the bugs out. /QUOTE]
