Adding 2nd Battery Under Front Seat - Page 8 - Ram Promaster Forum
post #71 of 76 Old 02-01-2017, 12:24 PM Thread Starter
slamit06
Quoted: 25 Post(s)
I have made continuous improvements on installing aux battery since this post a long time ago. The installs are way cleaner. I am now installing a 30AMP auto reset fuse from AUX to fuse panel then putting a 50AMP buss type manual disconnect fuse after this to the aux fuse panel. The auto reset fuse adds an additional layer of safety for running the aux power line in case of a short. The small panels I am using typically have a 100amp max...so this is more than sufficient for a small 10 position aux panel for low load use. As others have said you don't "need" to vent a AGM battery, I just did it because it was an added level of safety and super easy to do to run a simple air line from the box to the outside...just in case. Just like adding adding an auto reset fuse inline to the AUX panel. Not needed, but why not if it is easy.
slamit06 is offline
The Following User Says Thank You to slamit06 For This Useful Post:
Charger7022 (02-05-2017)
post #72 of 76 Old 02-01-2017, 12:41 PM
Quoted: 596 Post(s)
Just remember hydrogen, the escaping gas, is much lighter than air si the vent should rise, or be a very small vent line down.
post #73 of 76 Old 02-05-2017, 12:50 AM
Charger7022
Quoted: 14 Post(s)
I to installed a 30 amp auto reset between battery and panel. my box is also sealed and vented outside just in case!!! thanks again slamit06 this helped me a lot when installing my battery.
2016, 159" high top, Gas, converted to a camper for 4
Charger7022 is offline
post #74 of 76 Old 02-18-2017, 10:23 AM
Darral Simmons
Quoted: 1 Post(s)
OP, I followed you original install to the letter other than using a Autozone Branded Sealed Battery.
The Battery Doctor just has a blinking red light and pressing the button on it does not switch it to a different mode.
Any ideas on what I did wrong?
Thanks!
Darral Simmons is offline
post #75 of 76 Old 02-18-2017, 11:07 AM
tgblake
Quoted: 31 Post(s)
Thanks!
Check connections between Battery Doctor and Auxiliary battery. IIRC the blinking red light happens when you have properly connected the Battery Doctor to your main battery. Then when you connect to auxiliary battery, light should turn solid red.
2014 Gas Promaster 3500 159 EXT
tgblake is online now
post #76 of 76 Old 02-19-2017, 01:15 AM Thread Starter
slamit06
Quoted: 25 Post(s)
I have had one Batt Doctor go bad and was replaced no problem, but this is out of many I have used and after six months of use...however I would agree its very likely your connections are not right or you have a fuse issue? Follow the BD wiring diagram, make sure you fuse everything correctly; use the right wire and terminal connections and proper ground. You don't need to press the button if everything is correct; it's pretty straight forward. Where I see problems is incorrect wiring, terminal connections, fuses, improper wiring ...usually because corners where cut due to cost or convenience. Also always a sight chance your battery is bad...it helps to have a meter...if you don't have one invest in a good one for electrical work, it is a must to help trouble shoot quickly on all things electrical. Great YouTube videos on what to look for when purchasing one and how to use them. Buy a quality one; don't go cheap.
slamit06 is offline
