Interior lights in the cargo area - Page 4 - Ram Promaster Forum
post #31 of 40 Old 07-22-2014, 05:19 AM
Quoted: 455 Post(s)
PJ3P If they run on 3 AAA batteries that is only 4.5 volts did you just connect them up to 12v and they work or did you use a resistor and if so what size? IKEA has a few of LED lights that run off of 12v and they are cheap!
keeponvaning is online now
post #32 of 40 Old 09-09-2014, 02:15 AM
davejunkyard
The two cargo lights do have 3 positions. One is off, one is for 5 minutes, the other is for 16 minutes. I just timed them yesterday. After 16 minutes, the lense gets hot, so it's a good idea to have them on a timer.
davejunkyard is offline
post #33 of 40 Old 06-02-2015, 04:50 PM
gerrym51
Quoted: 6 Post(s)
Is there a way to shut off these lights in the cargo area and leave cargo side door or rear door open?
gerrym51 is offline
post #34 of 40 Old 06-02-2015, 05:14 PM
makevx73
makevx73's Avatar
Quoted: 120 Post(s)
Do you mean the lights that came with your PM?
If so posts 1 & 6 are your answer.
Gas/June 2014 Build/118" WB/Low Roof/Light Loads/Daily Driver
makevx73 is offline
post #35 of 40 Old 06-04-2015, 04:57 AM
ha3Dy_j1s
ha3Dy_j1s's Avatar
Quoted: 27 Post(s)
a little wire, a little solder ...
If you really want to do it on the cheap, Dollar Tree has inexpensive versions of these puck lights for a buck each. Can't remember if they use three batteries or two. If they use three batteries you can wire three lights in series and run off the 12V. If they use two batteries, wire four in series. You might want to short/defeat the push switch. Twelve lights would probably provide a fair amount of light for the back ... and the buck. Each light has three LEDs.
ha3Dy_j1s is offline
post #36 of 40 Old 06-04-2015, 07:00 AM
Quoted: 677 Post(s)
Or how about strip lighting along the ceiling or indirect lighting?
See:
Amazon Amazon
and you can have a remote controlled switch too:
Amazon Amazon
These can be cut to any length (within reason) and dimmed! They come in colors too! They are 12 volt already and have an adhesive back plus can be switched normally. For this sort of change why fool with the dollar store?
post #37 of 40 Old 06-04-2015, 04:01 PM
ha3Dy_j1s
ha3Dy_j1s's Avatar
Quoted: 27 Post(s)
Yes, very reasonable prices. Agreed. I plan on using LED strips hidden along tops of walls, bouncing light off curved ceiling panels like cove lighting. The dimmers are inexpensive too. They regulate brightness by pulse width, so I'd think they're effecient/energy saving.
And since my profile does say "hippie van", maybe I'll throw in some blacklight LEDs as well. Groovy, man!
2015 high-roof 1500 gasser, nicely optioned ... w/ leather wheel & one-too-many seats
post #38 of 40 Old 01-09-2016, 11:52 AM
ACRGLASS
Quoted: 6 Post(s)
After a lot of LED research on the bulb replacements for the OEM rear dome lights, we installed two of KC Highlites #1350 CLEAR Cyclone LED Accessory Lights, and tied them into the OEM dome light circuit @ the passenger side dome light by the cargo door. We also did change the rear OEM bulb to an LED card, but I don't recall the specs. We left the OEM bulb in the passenger side dome light, because it does little besides light the top shelf in our shelving unit now any way.
What we have is dome lights that function on the OEM timers, a lot of extra light that's working out well, and the only issue was I had to "insulate" mount the KC lights from a grounded mount. Apparently Fiat/Ram grounds the circuit to complete it to switch the lights on. It wasn't terribly difficult, we have many plastic "poke in" fasteners and double face tape pads that worked very nicely for the task.
I've attached a late afternoon pic with the lights on so there's very little light bleeding in from behind the camera.
Again, thanks to all that post for your ideas and suggestions also.
ACRGLASS is offline
post #39 of 40 Old 01-21-2016, 02:16 PM
Wildbill3
has anyone figured out were the fuse is for the lights in the back inside I didnt want to pull them all, looks like i will.
Wildbill3 is offline
post #40 of 40 Old 01-31-2016, 10:20 PM
mberk4
Quoted: 3 Post(s)
I clicked on the picture, it enlarged it
mberk4 is offline
