Clutch bleed? - Page 2 - Ram Promaster Forum
User Tag List
Reply
Thread Tools
post #11 of 50 Old 10-11-2016, 11:30 AM
RDinNHandAZ
Senior Member
RDinNHandAZ's Avatar
Quoted: 683 Post(s)
Garage
I’m guessing the tilt has something to do with a sensor and there is little else to invent here. I was guessing and suggesting a non-destructive possible solution that may have no effect but might lead to the code not setting. You are right low fluid should not trigger THAT symptom code. Either top it up a bit or don’t. Code P2872 is a generic code, I’d have confidence it is related to the clutch BUT perhaps not to that specific symptom. Really, what have you got to loose? BTW the fact it sets the code only when having set a bit also suggests air in the line or on an immersed sensor that is why they bled it. Just try’n
I just looked it up and now I want to confirm that the service people at your dealer said “Clutch stuck engaged” as that code is used by other manufacturers to sense voltage in the TPS circuit! That would be very different. I don't have the specific Fiat/Ram code source but they do. If the tech. just read out the code and looked it up on the internet you are probably not getting the correct symptom.
2015 136" HT Diesel Sandstone Metallic Born on 6/12/2015 Campervan build see: http://www.promasterforum.com/forum/...ad.php?t=37177
Have Leatherman, Will Travel
RDinNHandAZ is online now
Sponsored Links
Advertisement
post #12 of 50 Old 10-11-2016, 02:48 PM Thread Starter
mikesee
Senior Member
Quoted: 20 Post(s)
(Thread Starter)
Your musings and elucidations are much appreciated. My questioning wasn't intended to come off as argumentative -- I just wanted to continue the discussion.
Dealer couldn't translate that code into anything meaningful -- I googled it on my phone while they groped each other.
mikesee is offline
post #13 of 50 Old 10-11-2016, 04:45 PM
RDinNHandAZ
Senior Member
Quoted: 683 Post(s)
Garage
Yes I suspected that they didn’t/couldn’t find a specific FCA symptom for that code. They are going to have to investigate with whatever Ram has for tech. genius higher up. Don’t be surprised if next time they wiggle the wire at the TPS sensor! I’m stumped. Best to you and keep us informed.
post #14 of 50 Old 10-25-2016, 12:14 PM
d1rider
Junior Member
d1rider's Avatar
Quoted: 1 Post(s)
Garage
getting same p2872 occasionally,but works fine,can't tell diff,but would like to know actual manufactor code,will stay tuned
Hangtown Norcal,Diesel
d1rider is offline
post #15 of 50 Old 10-25-2016, 01:02 PM
RDinNHandAZ
Senior Member
Quoted: 683 Post(s)
Garage
That is three of us, please report it to FCA and ask our dealer’s techs some hard questions.
post #16 of 50 Old 11-15-2016, 10:33 AM Thread Starter
mikesee
Senior Member
Quoted: 20 Post(s)
(Thread Starter)
I want to give my dealer the benefit of the doubt -- in that they both have a clue and give a **** -- but they keep giving me reasons to doubt them.
I had to be out of town last Weds AM thru Sunday PM. Perfect time to give it to them for in-depth digging for this problem. Dropped it off on Weds AM early. First red flag was that my "normal" service writer wasn't there. Thus I had to go back and explain the history of this problem to the guy that I did get. They take notes and keep them in the computer, but they are brief, and vague, and you could read them from many different perspectives.
After 10+ minutes of explaining to him what is happening, he said he understood, then asked two questions, back to back, that told me he not only didn't understand but probably wasn't even listening to me. Needing to get to the airport *now* I didn't have time to start over. I reiterated the basics, got confirmation that he understood, then as I was leaving I told him for at least the 3rd time that I'd be in at 7:30 on Monday morning to pick it up.
I had a voice mail from him on Thursday afternoon telling me that they couldn't find anything, and that it was ready for pickup. When I did pick it up, on Monday morning as promised, he said they weren't even able to find a code in the system.
The next nearest dealer is over an hour away, and of unknown value. With the local dealer, I can leave the van and ride my bike home in 10 minutes. I'd like to keep it local, but how do I get through to these people and get them to give a **** about what I'm telling them?
mikesee is offline
post #17 of 50 Old 11-15-2016, 12:12 PM
KilWerBzz
Senior Member
KilWerBzz's Avatar
Quoted: 89 Post(s)
P2872-clutch 1 stuck engaged
P2872-CLUTCH 1 STUCK ENGAGED
Here's most of what they check and is sent to the cloud so every tech knows. I don't no what order they check but that is dependent on the previous check being a yes or no.
Run a scan and save the report in the files for future use.
Check the vehicle repair history.
Check transmission fluid level. The only way to check M40MTA level is to drain and refill with the correct amount.
Check clutch position sensor operation.
Check clutch solenoid valve operation.
Inspect clutch components.
Check wiring and connectors.
Check for aftermarket electronics that may be bundled with or near wiring harness that may cause EMI of the circuit.
2014 Ram Promaster 2500 HR 159" Diesel
Bow down to RA and offer him Cadmium Telluride and he shall reward you.
http://www.fuelly.com/car/ram/promas...lWerBzz/364918
KilWerBzz is offline
post #18 of 50 Old 11-15-2016, 01:48 PM
RDinNHandAZ
Senior Member
Quoted: 683 Post(s)
Garage
Thanks KWB,
I am beginning to doubt that generic code is used by FCA for the Clutch and here is why. None of the few of us who have gotten the P2872 code have reported any clutch or shifting symptoms, the code is generated once on startup or soon after, it happens at odd times not consistently, and there are internet references to that code being used for other sensors like the TPS although that has its own codes. I am guessing that as a generic code it was adopted by FCA for some sensor we have that is not common or not on the normal ODB2 code list (fluid level?). Have you or anyone heard that the Ram tech has searched FCA for the code as it seems to me they are searching the same internet we are. If so, we may all be misdirected? Or perhaps you can think what the clutch might be doing? I am at a loss so I am creating here. I also am trying to decide if there is anything I can do to investigate further if it repeats on my van. What do you (all) think?
post #19 of 50 Old 11-15-2016, 02:05 PM Thread Starter
mikesee
Senior Member
Quoted: 20 Post(s)
(Thread Starter)
I believe I am starting to feel a clutch issue. Immediately after it shifts the clutch doesn't completely disengage -- think pressing your foot lightly on the pedal of a modern manual trans car -- then after a second or two, it releases, and there is a subtle but noticeable increase in acceleration as this happens.
I am, admittedly, princess and the pea incarnate, and can detect (and want to fix) minute issues that others neither notice nor care about. I spent time explaining this issue -- how and when to feel it -- to the service writer last wednesday. When I picked the van up he gave the standard "unable to duplicate" response. I felt it again, immediately, when I drove off the lot.
mikesee is offline
post #20 of 50 Old 11-15-2016, 03:37 PM
KilWerBzz
Senior Member
KilWerBzz's Avatar
Quoted: 89 Post(s)
Not guessing them the facts.
This is how FCA lists this code for the promaster diesel. The checks I listed are correct but not to full context of the check. Disconnect the battery before you start messing with things. I would check all connections unplug and re-plug as the only thing that can be done without the starr scan tool and proper ohm readouts. There's a wire bundle, in front of the fuel filter, that contains trans wires the big connector and the little one. There is a sensor under the hydraulic reservoir good luck with that one. Check the reverse switch on the side of the trans sorry no pics. That's all I know for now.
https://goo.gl/photos/88mtden6M11oVWsVA
Oh if you drain the hydraulic fluid reservoir there is a procedure that needs to be followed and the trans may need to be retrained.
The Following User Says Thank You to KilWerBzz For This Useful Post:
RDinNHandAZ (11-15-2016)
Reply
Thread Tools
Forum Jump
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
