From outside in what are your layers?? Insulation - Page 2 - Ram Promaster Forum
post #11 of 24 Old 12-31-2016, 09:25 AM
MsNomer
MsNomer's Avatar
Quoted: 382 Post(s)
That eBay seller is Hein, a member here and on other similar forums. Search for him here and you may have the option of dealing directly. Really, really nice guy. His CNC-cut ABS items are top quality. I used his solar panel bracket feet, others have used the corrugated fan mount.
Once the Thinsulate is in, there's nothing to compress it. Pretty much a different animal from sewing, sticks well with 3M90. Don't use 3M77, which is a temporary bond.
I made a "van quilt" with Climashield, which I like better than Primaloft because it doesn't require tacking. Probably wouldn't pack down as tight as Primaloft, but that is irrelevant here.
Glad to meet another backpacker. Make sure you design in a dedicated space for the packs. They can be unwieldy.
MsNomer is online now
The Following User Says Thank You to MsNomer For This Useful Post:
medicineman4040 (01-01-2017)
post #12 of 24 Old 12-31-2016, 11:01 AM
cutndry
Quoted: 8 Post(s)
Yes, I agree. His products are very high quality. Highly recommended
Sent from my iPhone using Tapatalk
cutndry is offline
The Following User Says Thank You to cutndry For This Useful Post:
post #13 of 24 Old 12-31-2016, 11:43 AM
Rich Maund
Rich Maund's Avatar
Quoted: 11 Post(s)
100 sq ft of butyl rubber and foil sound mat insulation. Covered that in foil backed 1" foam and used spray foam to hold the pieces to the truck. Then furring strips and wood paneling. Used some mats of pink fiberglass insulation inside the doors. Floor is covered in heavy carpet padding and commercial carpet.
Huge decrease in road noise and temperature in the van stays much steadier for better comfort. Not an expensive route, but very good results IMO.
The senior member formerly known as Sidecarnutz.
Rich Maund is offline
The Following User Says Thank You to Rich Maund For This Useful Post:
post #14 of 24 Old 12-31-2016, 03:47 PM
my42ne
Is glue enough to hold the floor down? I can imagine a good washboard road or RR crossing shaking the whole loose and resulting in a permanent rattle and squeak.
my42ne is offline
post #15 of 24 Old 01-01-2017, 02:13 PM
Skaggydog
Skaggydog's Avatar
Quoted: 30 Post(s)
Ah... insulation commentary. Its as good as a back gouged "root opening" for a complete joint penetration grove in a welding forum
Have not done it yet but after much reading my plans so far,
butyl rubber sound damping material with an aluminum skin at about 25% per panel
Polyisocyanurate Rigid Foam glued on between ribs
Thinsulate or denim insulation threaded through the ribs and around the Rigid Foam
Reflectix over all with plastic or wood paneling holding it together
Please yell if you think this is a sick injustice to my Promaster
If it don't fit get a bigger hammer
2016 2500 159" Gas HT Glazed
To be a camper
Skaggydog is offline
The Following User Says Thank You to Skaggydog For This Useful Post:
DesertPhotoDude (01-01-2017)
post #16 of 24 Old 01-01-2017, 02:24 PM
Quoted: 745 Post(s)
Don't do the denim, it collects and holds moisture which forms from condensation. Thinsnsulate good, denim bad, even the non-itchy fiberglass would be better.
2015 136" HT Diesel Sandstone Metallic happy with the owner conversion. See: http://www.promasterforum.com/forum/...ad.php?t=37177
The Following User Says Thank You to RDinNHandAZ For This Useful Post:
Skaggydog (01-01-2017)
post #17 of 24 Old 01-01-2017, 05:13 PM Thread Starter
medicineman4040
medicineman4040's Avatar
Quoted: 107 Post(s)
Thinsulate is a done deal.
The she-boss was just pricing it and getting ready to order.
So for us outside--->in
air---van metal---pink foam board---thinsulate--paneling This one the walls.
From the top-
air van metal celing---Dynaliner--pink foam boad--thinsulate--paneling.
The pink foam board is this:
http://promasteraccessories.com/insulation.php
The paneling from Legen Fleet simply because it is
the 'whitest' looking one.
Our build will be very Euro-industrial looking!
medicineman4040 is offline
post #18 of 24 Old 01-01-2017, 07:12 PM
GaryBIS
Quoted: 118 Post(s)
From the top-
Hi,
I would not use the XPS or EPS white, pink or blue foam next to the van skin. They have a max service temperature of 160F. On a hot day in the sun, I think the van skin will go over this temp.
I've managed to make several thermal sculpture out of XPS: http://www.builditsolar.com/Experimental/pinkfoam.htm
It does not really take that high a temperature.
Polyiso has a max service temp of 270F and is fine -- would also give you more insulation value per inch.
Also wonder why you would want to stack Thinsulate with foam insulation? Some advantage to this over using just one or the other?
Gary
GaryBIS is offline
post #19 of 24 Old 01-01-2017, 08:31 PM
Quoted: 745 Post(s)
I don’t know where you might park that van but the interior, not just the skin, can reach 160 in most latitudes in the summer, if unprotected with no window shades. It might be just an occasional or inadvertent occurrence but it is likely to happen. My flat plate solar hot water heater panel is rated to max out (stagnate) at 165º but in February in full sun it will boil water if the circulator stops! DAMHIK. GaryBIS knows what he is talking about. Polyisocyanurate is easy to get at Lowes or HD and easy to cut and much cheaper than that kit. Why chance it? It and thinsulate from Hein are a better choice.
post #20 of 24 Old 01-01-2017, 09:41 PM
pjoconnor2001
Quoted: 3 Post(s)
Medicineman,
You might look hard at that insulation kit. I checked it out a few months ago and corresponded with Promaster Accessories about it. I advised them that the stated insulation value, i.e., 3/8" thick with R-38 performance, was essentially impossible, so there must be a typo or misprint somewhere. In their defense, they are a reseller, not the manufacturer. All I got from them was "All of the insulation technical data we have from the supplier is listed on the website".
Pete
2017 118" WB, Gas, Deep Cherry Red Crystal Pearl. Member-Dinky Van Clan .
pjoconnor2001 is offline
